Well... I just bought a Ryzen 5 1600, 16gb of Crucial DDR4 2400 RAM and an MSI B350M GAMING PRO. I got cocky and installed it all, and now it doesn't boot. I need help on why It's not showing up any signal, I think I've plugged everything in, but I'm out of my depth and scared. Just spent £377 on all the parts. The BIOS install is weird, I don't understand what I'm doing really. Any help would be appreciated, Thanks
https://linustechtips.com/topic/902439-i-need-help/
Do you have a GPU?
Intel Core i7 8700k | be quiet! Dark Rock 4 | Fatal1ty Z370 Gaming-ITX/ac | 32 GB G.Skill TridentZ | 256 GB Intel® SSD 600p Series | ZOTAC GeForce® GTX 1080 Ti Mini | Fractal Design Node 304 | Cooler Master V750 | Asus MG279Q | Asus VC279 | Logitech G710+ | Corsair M65 Pro RGB
https://linustechtips.com/topic/902439-i-need-help/#findComment-11104888
No GPU listed in your specs you gave.. the Ryzen 5 1600 does NOT have video card built onto it. It is a CPU only. This would be my assumption based on what you have listed.
Community Standards
"Beast Mode"
Dedicated Streaming Rig
https://linustechtips.com/topic/902439-i-need-help/#findComment-11104891
Also did you turn the Powersupply on?
    Quote=Reply      Feel free to tag me or sth if you have questions about Liquid Metal :) ROCKETS ARE LIFE        My current build:
CPU: I7 6700k@4.7Ghz 1.31sth V; Liquid Metal (Thermal Grizzly Conductonaut) | Cooler: Corsair H100iv2 | GPU: HIS R9 390 | Motherboard: Asus Z170-A | RAM: 16GB 2133Mhz HyperX FuryX | Storage: 1x 250GB Samsung 960 Evo 1x random 4TB 7200RPM HDD | Case: Lian Li Alpha  550W | PSU: Corsair RM650i | Misc.: 6x Lian Li 120mm Bora RGB Fans
My Build Log:
https://linustechtips.com/topic/902439-i-need-help/#findComment-11104895
Check this list:
https://www.msi.com/Motherboard/support/B350M-GAMING-PRO#support-mem-12
and make sure your exact RAM is on that list.
https://linustechtips.com/topic/902439-i-need-help/#findComment-11104937
3 minutes ago, NigeTarzanW said:
I've tried switching the HDMI from the GPU to the CPU, thought maybe that would work. Would I need to unplug my HDD or something? I have the BIOS plugged in with a USB. Maybe if I removed the HDD
What do you mean you have the BIOS plugged in with a USB? The BIOS is built into your motherboard. Do you mean operating system?
https://linustechtips.com/topic/902439-i-need-help/#findComment-11104943
I downloaded a BIOS update onto my other PC and plugged it into the Mobo. The OS is on the HDD
https://linustechtips.com/topic/902439-i-need-help/#findComment-11104962
