INTAKE + FILTERED =
top can fit 3*140
front 2*140
bottom 2*120
OUTTAKE =
rear 1*140
only the rear had no filters. I plan to have all other fans to be intake, and filtered. Extreme positive pressure to prevent dust buildup. Temperature is not a concern.
so only 1 outake, all others are filtered intake. Would this prevent most dust buildup? what alternatives are there?
https://linustechtips.com/topic/902361-view-71-dust-buildup/
Having a dust filter on exhaust is a non issue. Only need to have them on intake to limit dust intake. There is no such thing as a dust proof case, but having the filters on intake will greatly reduce the amount that enters.
Community Standards
"Beast Mode"
Dedicated Streaming Rig
https://linustechtips.com/topic/902361-view-71-dust-buildup/#findComment-11104260
15 minutes ago, pomkon said:
INTAKE + FILTERED =
top can fit 3*140
front 2*140
bottom 2*120
OUTTAKE =
rear 1*140
I would recommend you to watch the latest ltt video about dust buildup, it gives you a good general idea :)
    Quote=Reply      Feel free to tag me or sth if you have questions about Liquid Metal :) ROCKETS ARE LIFE        My current build:
CPU: I7 6700k@4.7Ghz 1.31sth V; Liquid Metal (Thermal Grizzly Conductonaut) | Cooler: Corsair H100iv2 | GPU: HIS R9 390 | Motherboard: Asus Z170-A | RAM: 16GB 2133Mhz HyperX FuryX | Storage: 1x 250GB Samsung 960 Evo 1x random 4TB 7200RPM HDD | Case: Lian Li Alpha  550W | PSU: Corsair RM650i | Misc.: 6x Lian Li 120mm Bora RGB Fans
My Build Log:
https://linustechtips.com/topic/902361-view-71-dust-buildup/#findComment-11104278
SO 7 filtered intakes + 1 outtake
because there is a large gap between glass panels, dust will be a problem
https://linustechtips.com/topic/902361-view-71-dust-buildup/#findComment-11104279
 take a look at this
My Build Log:
https://linustechtips.com/topic/902361-view-71-dust-buildup/#findComment-11104282
4 hours ago, pomkon said:
OUTTAKE
Outtake??? I think its just in and out.
Watch this video
https://youtu.be/dLX54ounENY
PC Specs:
CPU: Intel Core i7-12700K 3.6 GHz 12-Core
CPU Cooler: Corsair iCUE H150i ELITE CAPELLIX 75 CFM Liquid CPU Cooler
Motherboard: Asus ROG STRIX Z690-E GAMING WIFI ATX LGA1700
RAM: Kingston FURY Beast 32 GB (2 x 16 GB) DDR5-5200 CL40
Storage: Boot Drive: Samsung 960 Evo 250GB M.2 NVMe SSD
               Other Storage: Mass Storage: Western Digital Caviar Blue 1TB 7200 RPM, Western Digital Caviar Blue 2TB 5400 RPM, Scratch Disk: Intel X25-E SSDSA2SH032G1 32GB SATA II SSD, Backup Drive: Seagate ST3160318AS 160GB HDD
GPU: Asus GeForce RTX 3080 Ti 12 GB ROG STRIX GAMING OC
Case: Corsair 5000D AIRFLOW ATX Mid Tower
PSU: Silverstone Strider Platinum S 1000 W 80+ Platinum Certified Fully Modular ATX
OS: Windows 11 Pro 64-Bit
Monitors: Primary: Samsung S34E790C 34" 3440*1440 60 Hz UWQHD; Secondary: LG 34UM58-P 34" 2560*1080 75 Hz UWFHD; Tertiary: BenQ GL2460 24" 1920*1080 60 Hz FHD
Keyboard: Corsair K70 Mk. 2 RGB Gaming Keyboard - Black
Mouse: Corsair M65 Pro RGB FPS Gaming Mouse - Black, Logitech MX Master 3
Headphones: Corsair VOID PRO Surround Cherry 7.1ch
Speakers: Logitech Z213 7W 2.1ch
Laptop:
Asus Zenbook Pro 15 (UX535Li-E2018T) with Intel Core i7-10750-H 12MB @ 2.60GHz (Turbo @ 5.0 GHz), 16GB (2 x 8GB) DDR4 2933 MHz SODIMM and Intel(R) UHD Graphics; NVidia Geforce GTX 1650-Ti with Max-Q Design, using WDC NVMe PC SN730 SDBPNTY-1T00-1102, on a 96-Wh battery
NAS Specs:
Make & Model: QNAP TS-1277
CPU: AMD Ryzen 5 1600 @Stock
Hard Drives: x8 WD Red 2TB
SSDs (2.5"): x1 Samsung 850 Evo 250GB V-NAND (cache drive)
M.2 SSDs: None
RAID Configuration: RAID 6 (excluding SSD)
Total Storage: 12TB
Expansion Cards: None
https://linustechtips.com/topic/902361-view-71-dust-buildup/#findComment-11104286
