1 minute ago, Amyrro said:
Hi again
Thanks for the reply
I have been checking some threads on different forums.
Interestingly, I have found some, including this one, which refer to a shortcoming in SnapRaid, the it does not provide real-time protection.
https://hardforum.com/threads/unraid-or-snapraid-not-sure-which-one-to-go-with.1801222/
The turn-around suggested by the guy called "saiyan" is to set a windows scheduled task to get the realtime action of the parity drive.
Any thoughts ?!
yep no realtime protection, parity needs to be calculated manually on on a timer. Normally this isn't a big deal for home users as file aren't changing that often and you run a sync after a large copy.
