8700 Air Cooler
1 hour ago, SirFlamenco said:Any cooler smaller than 157mm height will work. I recommend Noctua.
The specs listed for the Spec-02 don't account for the side panel bump and it can fit slightly taller coolers.
2 hours ago, mpt50 said:I am Shopping in minnesota, so my options are microcenter, newegg, amazon, or anything online. Budget doesn't matter much, but water cooling wont work because of my case.
Depending on how much you prefer to spend, good options include:
M9i: https://pcpartpicker.com/product/LPVBD3/cryorig-cpu-cooler-m9i
PR Slim: https://pcpartpicker.com/product/hyQRsY/be-quiet-pure-rock-slim-351-cfm-cpu-cooler-bk008
Pure Rock: https://pcpartpicker.com/product/cwPzK8/be-quiet-cpu-cooler-bk009
Kotetsu: https://pcpartpicker.com/product/7998TW/scythe-cpu-cooler-scktt1000
