Is the Cooler Master MasterWatt 550 good enough for my system and overlock? And what tier is it?
Ryzen 5 1600 OC 3,850 Ghz 1.3750 Volt
GTX 1050 Ti OC +135 cor clock +635 memory clock
2x4 DDR4 2133Mhz OC 3066Mhz 1.400 Volt
2x 140mm Fans
MSI b350 Gaming plus
3 USB 3.0 devices
1 SSD 1 7200RPM harddrive
https://linustechtips.com/topic/901158-cooler-master-psu/
2x 140mm Fans
3 USB 3.0 devices
Go for it. It's a good PSU! And 550 is enough for your Rig
https://linustechtips.com/topic/901158-cooler-master-psu/#findComment-11092769
