Depends wich platform you want to use, and what your mobo budged it, i personally find it easier to just buy a extra fanhub (like this cheap one https://www.newegg.com/global/de/Product/Product.aspx?Item=9SIACJF6HF8558&cm_re=fan_hub-_-9SIACJF6HF8558-_-Product )(wow that's a long link)
If you need or want them on the mobo you first would have to decide on the platform you want to choose
    Quote=Reply      Feel free to tag me or sth if you have questions about Liquid Metal :) ROCKETS ARE LIFE        My current build:
CPU: I7 6700k@4.7Ghz 1.31sth V; Liquid Metal (Thermal Grizzly Conductonaut) | Cooler: Corsair H100iv2 | GPU: HIS R9 390 | Motherboard: Asus Z170-A | RAM: 16GB 2133Mhz HyperX FuryX | Storage: 1x 250GB Samsung 960 Evo 1x random 4TB 7200RPM HDD | Case: Lian Li Alpha  550W | PSU: Corsair RM650i | Misc.: 6x Lian Li 120mm Bora RGB Fans
My Build Log:
https://linustechtips.com/topic/900765-motherboard-fan-headers/#findComment-11088621
3 minutes ago, MrTheLegend said:
wait, (n00b moment incoming) they exist lol, can u please link me 1? thx
This is the one i would choose just froma quick look at it https://www.newegg.com/global/de/Product/Product.aspx?Item=N82E16811999340&cm_re=fanhub-_-11-999-340-_-Product
My Build Log:
https://linustechtips.com/topic/900765-motherboard-fan-headers/#findComment-11088626
2 minutes ago, thelordofwarr said:
Thanks so much man! youve been a huge help, :)
https://linustechtips.com/topic/900765-motherboard-fan-headers/#findComment-11088631
