1 minute ago, Cal12 said:
Ok so i have a gtx 1050ti installed and was looking in my display manager and under display adapters it still says AMD RADEON R7 GRAPHICS (i think this is my cpu) and then underneath my gtx 1050ti, should i disable the r7?
As long as it's outputting from the 1050 and defaulting to that in gaming load, you can just leave the R7.
Intel® Core™ i7-12700 | GIGABYTE B660 AORUS MASTER DDR4 | Gigabyte Radeon™ RX 6650 XT Gaming OC | 32GB Corsair Vengeance® RGB Pro SL DDR4 | Samsung 990 Pro 1TB | WD Green 1.5TB | Windows 11 Pro | NZXT H510 Flow White
Sony MDR-V250 | GNT-500 | Logitech G610 Orion Brown | Logitech G402 | Samsung C27JG5 | ASUS ProArt PA238QR
iPhone 12 Mini (iOS 18.3) | iPhone 15 (iOS 18.3.1) | KZ AZ09 Pro x KZ ZSN Pro X | Sennheiser HD450bt
Intel® Core™ i7-1265U | Kioxia KBG50ZNV512G | 16GB DDR4 | Windows 11 Enterprise | HP EliteBook 650 G9
Intel® Core™ i5-8520U | WD Blue M.2 250GB | 1TB Seagate FireCuda | 16GB DDR4 | Windows 11 Home | ASUS Vivobook 15
Intel® Core™ i7-3520M | GT 630M | 16 GB Corsair Vengeance® DDR3 |
Samsung 850 EVO 250GB | macOS Catalina | Lenovo IdeaPad P580
I think the Nvidia control panel lets you choode which card is in use under different applications, in "3D Settings" somewhere (This is anecdotal from my experience with embedded systems)
However, you should be able to disable the integrated graphics in the bios.
