21 minutes ago, meidal11 said:
it's like that on EVERY game. i can't play overwatch on a decent 170fps, and absolutely not stream, fps is getting to 90-130.
gtx 1080
r7 1700
2x8 3000mhz (2933 bios)
i'll post any information you want, just help me fix it :(
Are you running the latest bios? Many Ryzen issues are resolved by updating the bios :)
PC Specs: Intel Core i7-8700k - Asus ROG Z370 MAXIMUS X HERO - 2x8gb Kingston Predator DDR4 3200MHz - MSI GeForce GTX 1080 Ti gaming X Be Quiet! Dark Rock Pro 4 - Samsung 850 PRO 256gb - Samsung 850 EVO 500gb - Seagate Barracuda 2tb - Fractal Design Meshify C - Asus PCE-AC56 - Be Quiet! Straight Power 10 CM 700W.
Peripherals: Corsair K70 LUX - Steelseries Rival 310 - Dell S2417DG - Beyerdynamic Custom One Pro - Audioengine D1.
https://linustechtips.com/topic/899795-r7-1700-1-core-problem/#findComment-11079335
16 minutes ago, Yoola said:
I think there's something in AMD WattMan or whatever that's called now that's causing this.
Also, did you switch from another motherboard to Ryzen lately?
I switched my PC - sold my old i5 PC and bought this one, 100% new all its componants
https://linustechtips.com/topic/899795-r7-1700-1-core-problem/#findComment-11079367
So fresh Windows install happened?
I remember a while back I had simmilar issue, and even cleaning drivers with DDU and other stuff didn't help. Only thing that worked was to reinstall Windows. Still to this day I do not know what was actually wrong.
https://linustechtips.com/topic/899795-r7-1700-1-core-problem/#findComment-11079659
