Okay, so as some of you may know, Bf4 is a horrible mess right know when using sli. I have a gtx690, a dual gpu card, where sli must be turned off for the game to work.
So I do this, game works fine, blah blah blah. When I am done, I go back to re-enable sli, the usual black screen occurs and I go grab some food. I come back, still black screen, so I reset in safe mode to be sue I didn't beak anything. Ok everything seems to be good.
Boot in normal mode, display drivers don't seem be working. I try to access the nvidia control panel, it doesn't work. It tells me there is no nvidia gpu connected to my display, but mind you, my monitor is still plugged in to the card.
I tried tAking the cad out and putting it back in, still nothein
I haven't exhausted all my ideas but I am bit short on time today...
CPU:i7 3770k
Motherboard:z77x-ud4h (I know kinda bottle necked)
Apologies for my hasty typing.
Plz halp
https://linustechtips.com/topic/89968-problem-with-nvidia-driverscard/
Reinstall drivers.
Just normally?
Yup, I've have the same problem as you've described. Reinstalling the drivers fixes it.
Alternatively you could uninstall your drivers using DriverSweeper and making sure to tick the box that removes any left over files, I have had times where some files were not removed (I was unaware they were not gone)and it conflicted with the drivers I then installed. I use DriverSweeper from now on and it cleans every little bit of driver :)
Current Build: Case: Define R4 White/Window CPU: i5 3470 @4.0Ghz GPU: GTX 680 DCUII +500Mhz(Mem) Cooler: Hyper 212 EVO Monitor: Acer Monitor 1920x1080 MOBO: Asrock Z77 Extreme 4 Storage: 2TB HDD, 120GB 840 EVO (OS)
Future Build: 4670K, GTX 780 MSI TwinFrozr OC, Z87X-D3H, 8GB @1866Mhz, 120GB SSD, 1TB HDD, 750D, RM 650W, Custom Loop. White/Blue/Black Colour Scheme. I literally cannot wait *_*
