hi everyone.. im planning on doing a raid 0 on my gaming rig.. ive never done this so any help/tips is much appreciated..
the hdds im planning to use are:
1 x 2tb wd black 7200 rpm 64mb cache
2 x 1tb wd blue 7200 rpm 64mb cache
os: windows 10 home 64 bit
cpu: ryzen 5 1600
motherboard: asus prime b350
thank you for your patience..
https://linustechtips.com/topic/898995-raid-0-help/
Why do you want to Raid 0?
Want to know which mobo to get?
Choose whatever you need. Any more, you're wasting your money. Any less, and you don't get the features you need.
Only you know what you need to do with your computer, so nobody's really qualified to answer this question except for you.
chEcK iNsidE sPoilEr fOr a tREat!
https://linustechtips.com/topic/898995-raid-0-help/#findComment-11071085
