Hey,
So I've ordered all my parts for my new PC, and there's one quick question that I have in regards to whether I have enough fan headers. My motherboard is the Asus ROG Strix X370-F, and I'll have it in a H500P (hate all you want). There'll be five fans, the two stock 200mms and 3 120mms that I already have.
In short, my question is do I have enough headers? The specsheet for the motherboards say the following:
1 x CPU Fan connector(s)
1 x CPU OPT Fan connector(s)
3 x Chassis Fan connector(s)
1 x AIO_PUMP connector
1 x W_PUMP+ connector
I see 3 chassis headers, but I have 5 fans. Do I need to buy splitters from my local MSY? Or can I use the pump headers as well? Does the case actually come with power splitters? I know it comes with an RGB splitter.
Thanks in advance,
Jaeger
HEADS UP, THIS ACCOUNT IS INACTIVE NOW
I'm keeping everything else the way it was for anyone who might check out my answers in future, but I won't be using LTT.
Don't forget to quote me when replying to me!
Please explain your question fully, so I can answer it fully.
PSU Tier List Cooler Tier List SSD Tier List  My Specs Below!
My PC:
CPU: Ryzen 5 1600 @ 3.2GHz
Cooler: Stock Wraith Spire
RAM: G.Skill Trident Z RGB 3000mHz 16GB DDR4 (2x8GB) RGB
Motherboard: Asus ROG Strix X370-F Gaming ATX
SSD: Crucial MX500 500GB 2.5"
HDD: Western Digital Blue 1TB 7200rpm
GPU: Asus ROG Strix OC GTX 1060 6GB
Case: Cooler Master H500P
PSU: Corsair RM650i 650W 80+ Gold Fully Modular
OS: Windows 10 Home 64-bit
Fans: 4x Cooler Master Masterfan Pro 120 Air Balance
Potato Laptop (Samsung Series 5 Ultrabook, 2013):
CPU: Intel Ivy Bridge i5 3337U @ 1.8GHz
RAM: 8GB DDR3 2133mhz SODIMM (1x4GB Samsung, 1x4GB Kingston)
SSD: Kingston 24GB SSD (originally for caching)
HDD: HGST 500GB 5400rpm
GPU: Intel HD 4000 Graphics
https://linustechtips.com/topic/898954-splitters-required/
59 minutes ago, Pangea2017 said:
The H500p looks great if they replace the acrylic with something good (mesh version is great). No hate for the case if you mod the front air input.
I won't be doing that, I think the reason it got shit on by some reviewers is just that it was advertised as a HAF case and turned out to be more average.
Other than that, thanks for the advice. Since I'm picking up my parts in-store I'll ask them there as well and since the splitters are $3 each it couldn't hurt.
My PC:
https://linustechtips.com/topic/898954-splitters-required/#findComment-11070871
