R1200 doesn't have an iGPU.
Ryzen 5 1600 @ 3.9 Ghz  | Gigabyte AB350M Gaming 3 |  PaliT GTX 1050Ti  |  8gb Kingston HyperX Fury @ 2933 Mhz  |  Corsair CX550m  |  1 TB WD Blue HDD
Inside some old case I found lying around.
https://linustechtips.com/topic/898405-first-build-20/#findComment-11065178
7 minutes ago, KAN1102 said:
The build at the top is still bad, the list I added could also be revised if you don't like certain parts, but the cpu/motherboard should stay, unless you have more money to spend.
https://linustechtips.com/topic/898405-first-build-20/#findComment-11065452
Hey...FYI my budget is LOW!!(48K INR-700 USD
https://linustechtips.com/topic/898405-first-build-20/#findComment-11065773
I agree a whole lot to what you have done....might just get a GPU for video editing and mining(or not-'cause of Vega 11).The bios is the only part that I am kinda not okay with.
https://linustechtips.com/topic/898405-first-build-20/#findComment-11066166
