FIrst PC build
Solved by brob,
18 minutes ago, Apepa said:1. The Carbide 100R comes with 2 case fans included. You don't need to buy another one.
2. Most AMD APUs/CPUs come with an included cooler. There's no point buying an aftermarket one at this budget, especially such a cheap one.
3. Ryzen G would be a much better choice of APU.
Corsair lists a single 120mm fan (rear) for the 100R; http://www.corsair.com/en-us/carbide-series-100r-mid-tower-case. An intake fan is a good idea.
