Quick questions
I have an AsRock Z77 Pro 3 motherboard. 4 RAM slots (A1, A2, B1, B2)
1. My Crucial Ballistix Sport 8GB 1600Mhz CL9 is currently running at 2133Mhz CL11 (This is in slot A2) Can I put another 4GB ram stick? Will put it in slot A1 which will not run it in dual channel. Question is, will it run the 8gb stick at 2133mhz and the 4gb at 1600mhz or will it default both to 1600mhz?
2. Can I combine different size sticks? Hoping to add a Team Elite 4GB 1600MHz CL11 stick. In total of 8+4 = 12GB ram
3. Should I put it in a different slot? Or can I run them in dual channel? (A2, B2)? If not, can I still use it but put it in slot A1?
4. My current 8GB stick is CL9 and the 4gb is CL11, will I run into complications if I use them both?
PS: If it is okay, I will remove the overclock and run the Crucial stick at default which is 1600mhz CL9
Thanks
https://linustechtips.com/topic/898059-ram-questions-please-help/
7 minutes ago, MultiMigo said:
Quick questions
Thanks
As long as both sticks have the same CL and same voltage the sticks should work fine. As for different CL number the sticks will not run. So you'd better get two sticks with same CL. If voltage is lower on a ram stick them both sticks will run at the lowest voltage between the two ones. (if you have 2133 and 1600, both wil run 1600).
 || CPU: Intel i5-8600K || Cooler: CoolerMaster Hyper 212X || Motherboard: Gigabyte Z370 HD3P || GPU: Gigabyte GTX 1050ti OC Windforce 4GB || Memory: 16GB Crucial DDR4 3000mhz || HDD: WD Black 500GB + Seagate Barracuda 2TB || SSD: Samsung 980 1TB || PSU: Corsair VS550 || Case: nJoy Ice Cage || Fans: Segotep Halo Ring RGB ||Monitor: 2x Dell 27" P2717H IPS Full HD || Second Monitor/TV: LG 49UJ620V UHD || Mouse: Logitech G502 || Keyboard: Logitech G810 + Royal Kludge RK84 || Speakers: Philips SPA-5300 subw + Arylic 2.1 + DIY Bookshelves w/ Dayton Audio || Headphones: HyperX Cloud Flight S ||
TO BE UPGRADED:
>> Headphones << >> Keyboard << >> HDD << >> Mouse << >> PC Case << >> Memory(another stick) << >> Graphics Card <<
Hmmm. Are you sure about that? Will wait for more replies. Some articles I have seen said you can mix if you have the same voltage and frequency even if you have different CL. Thanks for the input. I'm not sure so will wait for more replies.
It's not great to mix match different sticks especially from different brands but it can be done
PC Specs:
CPU: Intel Core i7-12700K 3.6 GHz 12-Core
CPU Cooler: Corsair iCUE H150i ELITE CAPELLIX 75 CFM Liquid CPU Cooler
Motherboard: Asus ROG STRIX Z690-E GAMING WIFI ATX LGA1700
RAM: Kingston FURY Beast 32 GB (2 x 16 GB) DDR5-5200 CL40
Storage: Boot Drive: Samsung 960 Evo 250GB M.2 NVMe SSD
               Other Storage: Mass Storage: Western Digital Caviar Blue 1TB 7200 RPM, Western Digital Caviar Blue 2TB 5400 RPM, Scratch Disk: Intel X25-E SSDSA2SH032G1 32GB SATA II SSD, Backup Drive: Seagate ST3160318AS 160GB HDD
GPU: Asus GeForce RTX 3080 Ti 12 GB ROG STRIX GAMING OC
Case: Corsair 5000D AIRFLOW ATX Mid Tower
PSU: Silverstone Strider Platinum S 1000 W 80+ Platinum Certified Fully Modular ATX
OS: Windows 11 Pro 64-Bit
Monitors: Primary: Samsung S34E790C 34" 3440*1440 60 Hz UWQHD; Secondary: LG 34UM58-P 34" 2560*1080 75 Hz UWFHD; Tertiary: BenQ GL2460 24" 1920*1080 60 Hz FHD
Keyboard: Corsair K70 Mk. 2 RGB Gaming Keyboard - Black
Mouse: Corsair M65 Pro RGB FPS Gaming Mouse - Black, Logitech MX Master 3
Headphones: Corsair VOID PRO Surround Cherry 7.1ch
Speakers: Logitech Z213 7W 2.1ch
Laptop:
Asus Zenbook Pro 15 (UX535Li-E2018T) with Intel Core i7-10750-H 12MB @ 2.60GHz (Turbo @ 5.0 GHz), 16GB (2 x 8GB) DDR4 2933 MHz SODIMM and Intel(R) UHD Graphics; NVidia Geforce GTX 1650-Ti with Max-Q Design, using WDC NVMe PC SN730 SDBPNTY-1T00-1102, on a 96-Wh battery
NAS Specs:
Make & Model: QNAP TS-1277
CPU: AMD Ryzen 5 1600 @Stock
Hard Drives: x8 WD Red 2TB
SSDs (2.5"): x1 Samsung 850 Evo 250GB V-NAND (cache drive)
M.2 SSDs: None
RAID Configuration: RAID 6 (excluding SSD)
Total Storage: 12TB
Expansion Cards: None
no need to match the CL, it will run at the slowest.
As for different capacity, it will run in asynchronous dual channel.
Contrary to what many beliefs, mixing ram is fine, dual channel rules are not that strict.
this topic have been discussed lately, go search.
Indeed some people said the sticks should work. You could also try that by yourself. If it boots, then the sticks should work. But your PC might/may become unstable, meaning you could get blue screens. If you want something stable you'll have to adjust the CL for both sticks, in bios, which is pretty difficult and then run a mem test in order to make sure both work fine. Or take the easy way and buy a stick with the same CL/Voltage as the one you already have. Memory could be easily matched in bios so that won't be a problem at all.
TO BE UPGRADED:
So basically, I can run an 8 gig stick and a 4 gig stick in async dual channel if it has the same mhz, cl, and voltage?
never tried it, but i suppose so.
but if all fails, it just run a single channel.
no biggie
no biggie
Ahhhh. That one! Thank you!
Last question
the 4GB stick I will get is in CL11, the 8gb I have is CL9. Same voltage and freq
If I run them in single channel, would it work?
Yes, thats because im in the "you must match the same size" camp. Never knew you can also get dual channel with different sizes.
In single channel different CL will work, that i know for sure.
