How Loud Should A Closed Loop Pump Be?
Go to solution Solved by Imabigmac,
on the rear of the case, I have to mount it with the tubes at the top of the rad as there's no room for the tubes at the bottom, could that be an impact?
if the noise is in fact air then yes.
I've got a H55, and I can hear little like clicking noises coming from it, it's not very loud really, but I was wondering how loud genuinely you should expect it to be?
CPU: Ryzen 5 3600 | Cooler: Stock | RAM: 16GB Hyper Fury X RGB | GPU: RTX 2080 Super FTW3 | Motherboard: Gigabyte Aorus Elite| PSU: Corsair RM850x
Storage: WD SN750 500GB / 850 500GB Samsung Evo /  | CASE: 570X | Display: Dell u2414h  | KEYBOARD: Corsair K70 | MOUSE: Corsair M65
https://linustechtips.com/topic/89772-how-loud-should-a-closed-loop-pump-be/
i have a h80 and i dont have a clicking sound :S
Do u have any sound at all?
They aren't quiet by any means, but a clicking noise from pump may be a bad thing. Although the noise could be from the fan.
Corsair 400C- Intel i7 6700- Gigabyte Gaming 6- GTX 1080 Founders Ed. - Intel 530 120GB + 2xWD 1TB + Adata 610 256GB- 16GB 2400MHz G.Skill- Evga G2 650 PSU- Corsair H110- ASUS PB278Q- Dell u2412m- Logitech G710+ - Logitech g700 - Sennheiser PC350 SE/598se
Is it just me or is Grammar slowly becoming extinct on LTT?
I'll upload a video now
http://youtu.be/n0ORtrb_0Uo
Is that normal?
That's weird. It could air could also be a bad pump. How it's rad mounted?
Same cooler, same noise. Even with the pump full on in the BIOS, meaning "no auto", disabled cpu fan control, it still would do it at the beginning. It went away if I leaned the case over. When mounted on the top I would get no noise, but on the rear it would click. I personally believe it was trapped air. Try the leaning method.
Any air in the system will be at the top of the rad. Not good to have the hoses at the top. Go for sides if possible. Bottom is preferred.
Air 540, MSI Z97 Gaming 7, 4770K, SLI EVGA 980Ti, 16GB Vengeance Pro 2133, HX1050, H105840 EVO 500, 850 Pro 512, WD Black 1TB, HyperX 3K 120, SMSNG u28e590d, K70 Blues, M65 RGB.          Son's PC: A10 7850k, MSI A88X gaming, MSI gaming R9 270X, Air 240, H55, 8GB Vengeance pro 2400, CX430, Asus VG278HE, K60 Reds, M65 RGB        Daughter's PC: i5-4430, MSI z87 gaming AC, GTX970 gaming 4G, pink air 240, fury 1866 8gb, CX600, SMSNG un55HU8550, CMstorm greens, Deathadder 2013
ye the case is a define mini, and it has that side mounted extension panel for the fan controller which stops me from mounting it with the hoses at the bottom, and there's not enough clearance at the top, clashes with cpu 8pin, atleast I know what it is now :)
