Hello there,
I've got gmod for quite a while now but haven't really played it. Some of my friends started playing now and they are able to just join a server and play, while I never get the chance to play.
There's always something wrong. One time there are maps missing from cs (although I do have cs go and my friends don't have any cs and they can play fine), the other time everything is just pink and black with huge "errors" standing everywhere...
If anyone knows how to fix it, that'd be awesome :)
Thanks!
i5 4670k - MSI GTX 770 gaming - Fractal design define R4 (windowed) - MSI Z87-G45 gaming - be quiet! Dark Rock Pro 2 - Corsair vengeance 8 gb (lp) - WB black 1tb - 256GB SSD - Corsair TX 750M - Ducky Shine 3
https://linustechtips.com/topic/89761-gmod-never-works/
Hello there,
Thanks!
You can easily google the texture missing error there is a site that has the assets and textures for all the source games and you can out those in the good folder to fix the issue
https://linustechtips.com/topic/89761-gmod-never-works/#findComment-1213389
You need CSS files, but you can find content packs online that fixes all of those problems. It even says on the store page that you need these games in order to play. Gladly it has been made easy for those who don't have the games.
Now I've installed those packs, gmod still thinks I shouldn't play so now server don't show up and whenever I try to start a single player map, it goes to the main menu without doing anything.
https://linustechtips.com/topic/89761-gmod-never-works/#findComment-1213493
Well, i also want to play Gmod. But don't know how to join a server.
 [spoiler=CORMAC]CPU:Intel celeron 1.6ghz RAM:Kingston 400mhz 1.99gb MOBO:MSI G31TM-P21 GPU:Will add one later on! CASE:local ROUTER D-Link 2750U, D-LINK 2730U MOUSE:HP,DELL,ViP KEYBOARD: v7 SPEAKERS:Creative 245  MONITOR:AOC E970Sw HEADSET: Sony MDRx05s UPS:conex ups avr 500va PSU:idk OD:Samsung super writemaster STORAGE:80 gb seagate+ Seagate 1TB OS:Windows xp sp3 themed to Windows 7 + Linux |Rest all pc in my house will be updated from time-time
COMING SOON
https://linustechtips.com/topic/89761-gmod-never-works/#findComment-1213507
A friend of mine didn't have CS but downloaded the textures from somewhere to avoid the errors when joining a game.
 Asus M5A99X Evo  - AMD FX-8350 - 16GB Corsair Vengeance 1866Mhz - Corsair 120mm Quiet Edition Fans BenQ XL2411Z- EVGA GTX 980 Superclocked Fractal Design Define R4 - Corsair H100i - 2 TB 7200rpm HDD - Samsung 840 Evo 120GB - Corsair RM750w PSU - Logitech G502 Proteus Core - Corsair K70 RGB MX Red - Audio Technica M50x + Modmic 4.0 - LG 23EA63V x2
Spinthat Spinthat Spinthat Spinthat
https://linustechtips.com/topic/89761-gmod-never-works/#findComment-1213521
Did you enable them? I think you do it from the bottom right corner.
https://linustechtips.com/topic/89761-gmod-never-works/#findComment-1213615
I got a pack from the workshop. I also see the maps in the single player selection screen, so I think that's fine. I just get a white screen instead of a server choice thing and can't start single player maps.
https://linustechtips.com/topic/89761-gmod-never-works/#findComment-1214032
http://www.youtube.com/watch?v=dxuw7C3Zs-Q
https://linustechtips.com/topic/89761-gmod-never-works/#findComment-1214041
