Basically I bought a hd 6990 , it’s got some weirdness going on, screenshots of the two GPUs in gpu z attached. The card appears correctly in device manager though. Any ideas what this issue could be? A dying card? Driver fault?
Any ideas would be appreciated :)
My PC (Known as Theseus IV):
—CPU: R9 5950X (B2 Stepping)
—Ram: 32GB Vengeance Pro SL RGB
—Graphics: AMD RX 6900XT
—Motherboard: Asus ROG C8DH
—Storage: 990 Pro 2TB
—CPU Cooling: NZXT Z73 RGB 360
—Case: Corsair 5000D Airflow
—PSU: Corsair AX850
https://linustechtips.com/topic/896176-sapphire-hd-6990-issues/
Honestly; I got it out of randomness, a semi decent back up of sorts?
Ive read up; all sorts but nothing shows these kinds of oddness,
other than drivers , could this be a fault of hardware anywhere?
—PSU: Corsair AX850
https://linustechtips.com/topic/896176-sapphire-hd-6990-issues/#findComment-11041780
“Being a turd” I like it! Haha
i shall do, I’m hoping it’s merely drivers and software being crap,
how likely is it a faulty 6990? I mean these get toasty and they’ve been around a while?
Thanks for the suggestions.
—PSU: Corsair AX850
https://linustechtips.com/topic/896176-sapphire-hd-6990-issues/#findComment-11041879
