1 minute ago, PlanE said:
I need help building my first pc i only have 800$ so im pretty sure you guys might say get a amd ryzen cpu but idk what parts to get to get the best gaming experience with that price range
I'd wait till gpu prices stop being arse, but if you want to build right now:
PCPartPicker part list: https://pcpartpicker.com/list/cJBypG
Price breakdown by merchant: https://pcpartpicker.com/list/cJBypG/by_merchant/
CPU: AMD - Ryzen 5 1600 3.2GHz 6-Core Processor  ($189.00 @ Amazon)
Motherboard: MSI - B350 PC MATE ATX AM4 Motherboard  ($55.98 @ Newegg)
Memory: Team - Dark 16GB (2 x 8GB) DDR4-3000 Memory  ($165.75 @ Newegg)
Storage: ADATA - Premier Pro SP600 128GB 2.5" Solid State Drive  ($47.99 @ Amazon)
Storage: Toshiba - 1TB 3.5" 7200RPM Internal Hard Drive  ($42.19 @ OutletPC)
Video Card: Gigabyte - GeForce GTX 1050 Ti 4GB Video Card  ($214.98 @ Newegg)
Case: Cooler Master - MasterBox Lite 5 ATX Mid Tower Case  ($43.98 @ Newegg)
Power Supply: Corsair - TXM Gold 550W 80+ Gold Certified Semi-Modular ATX Power Supply  ($49.99 @ Newegg)
Total: $809.86
Generated by PCPartPicker 2018-02-11 09:43 EST-0500
https://linustechtips.com/topic/895377-help-building-first-pc/#findComment-11033086
Total: $809.86
yes i was planning on checking around April to see if the gpu prices went down again haha
https://linustechtips.com/topic/895377-help-building-first-pc/#findComment-11033091
if you're buying on april then ask at that time, prices and availability will change.
https://linustechtips.com/topic/895377-help-building-first-pc/#findComment-11033173
If you want to go Ryzen APU (releases tomorrow) you could do something like below:
ASRock AB350 Gaming-ITX ($130)
Corsair Dominator DDR4 3200 16GB ($226)
Cooler Master Elite 110 Case ($70)
Ryzen 5 2400g ($170)
WD Blue 1TB 3.5 inch HDD ($50)
Silicon Power 120GB SSD ($45)
Corsair CX-450M PSU ($60)
Corsair Hydro H60 Cooler ($70)
Cooler Master 80mm Fan ($6)
total - - - - - - - - - - - - -$827
(amazon prime)
Could easily get under $800 with an mATX board and case. No competitor to discrete graphics, but another option for 1080p none the less.
https://linustechtips.com/topic/895377-help-building-first-pc/#findComment-11034145
