Hey I have a pre-built computer from best-buy and now I'm going to upgrade it so I can actually run games on. Here is the old computer.
Operating System-
Microsoft Windows 8 64-bit
CPU-
Intel Core i7 3770 @ 3.40GHz 42 °C
Ivy Bridge 22nm Technology
RAM-
16.0GB Dual-Channel DDR3 @ 807MHz (11-11-11-28)
Motherboard-
ASUSTeK COMPUTER INC. CM6330_CM6630_CM6730_CM6830_M11AA (LGA1155) 39 °C
Graphics-
2048MB GeForce GT 630 (ASUStek Computer Inc) 37 °C
Hard Drives-
932GB Western Digital WDC WD10EZEX-22RKKA0 (SATA) 39 °C
Optical Drives-
ATAPI DVD A DH24ACSH ATA Device
Audio-
Realtek High Definition Audio
What do you think I  should salvage? here is what I'm planning on using http://pcpartpicker.com/user/MCmcginness/saved/3a3T. Any suggestions?
Thanks for the help.
CPU, 8350 @ 4.3 ghz | CPU COOLER, Hyper 212 EVO | ,MOBO, Gigabyte UD3 AM3+ 990FX | RAM, 8 gb  G.Skill ripjaw 1866mhz | GPUASUS 7970 | CASE, Corsair 230T black and red STORAGE, WD caviar blue 1 TB 7200 rpm | PSU, XFX 750 watt 80+ gold | Keyboard, K70 mx blue (black/red) | Mouse Razer naga hex, | Monitors, Asus VG248QE 24in 1080p, Dell 24in monitor 1080p |
https://linustechtips.com/topic/89515-upgrade-from-a-pre-built/
I had the Zalman Z11 and wouldn't recommend it since the fans are loud and it is really hard taking the front cover off and the case is really ugly in person :P
You could get one of these
http://pcpartpicker.com/part/fractal-design-case-fdcaarcr2blw
http://pcpartpicker.com/part/corsair-case-300r
But you probably want it with fancy lights to look like a gaming PC lol
i3-2120|4gb 1333|GTX 650ti 1gb|Fractal R4|Corsair 430w
https://linustechtips.com/topic/89515-upgrade-from-a-pre-built/#findComment-1209905
your cpu is locked(non K) so a z68/z77 mobo is useless.keep the one you have. just get a power supply and a r9 280X and you are fine for a long time.couse you see,its the gpu that is weak in your pc
i reccommend rosewill capstone 550M .the hive is not bad but its really miles apart from the capstone in performance and stability.also its 80+ gold and just a few bucks more than hive.550W is more than you will ever need for single gpu
choose whichever case you like
https://linustechtips.com/topic/89515-upgrade-from-a-pre-built/#findComment-1209949
Would you recommend a 770 or a 280x instead of the 270x? Either way which brand would you recommend?
Thanks
https://linustechtips.com/topic/89515-upgrade-from-a-pre-built/#findComment-1210480
Thanks
yes i would couse i see you have the budget. and brand? gigabyte windforce,msi gaming twin frozr and asus directCU2. flip a coin
then later add a SSD
https://linustechtips.com/topic/89515-upgrade-from-a-pre-built/#findComment-1212386
 My budget would be 900 USD I made a couple of changes.
http://pcpartpicker.com/p/2lPVt
https://linustechtips.com/topic/89515-upgrade-from-a-pre-built/#findComment-1214066
Oh sorry that was the wrong list that was one a friend sent me. My bad. ya Im getting the haf 922, a 270x gigabyte, and a corsair CX 600
https://linustechtips.com/topic/89515-upgrade-from-a-pre-built/#findComment-1214478
