If you are referring to the loading ring for Windows 10 then turn off the laptop, remove any USB dongles or anything like that and boot the laptop. For some reason after some Windows updates it won't fully boot with a USB mouse dongle or something of the sort plugged in. Not sure why but I have had this problem with many computers.
Main Rig
CPU: Intel Core i7 920 @ 4.0GHz
Motherboard: ASUS P6T SE
RAM: 10GB OCZ DDR3 (Triple Channel) @ 1600MHz
GPU: NVIDIA GeForce GTX 770 2GB
Case: Antec GX500 Window
Storage: 2 x 500GB Samsung 7200RPM HDD
PSU: Coolmax 1200W ATX 80 PLUS GOLD
Cooling: DEEPCOOL GAMMAXX 300
Teamwolf Mechanical Gaming KeyboardASUS ROG GX850 Laser Mouse
Main Laptop
Alienware 17 (2014)
(Intel Core i7 4710mq @ 2.5GHz - 3.5Ghz (Turbo) | 16GB DDR3 RAM | 4GB AMD m290x Dedicated Graphics - 1TB SSHD)
XP Machine (build in progress...)
CPU: AMD Athlon 64 3000+ @ 1.8GHz
Motherboard: DFI LANPARTY NF4
RAM: 1GB OCZ DDR (Dual Channel) @ 400MHz
GPU: NVIDIA GeForce GT610 2GB Synergy Edition
PSU: BFG 450W
Apple iMac (2009)
CPU: Intel Core2Duo @ 2.66GHz
RAM: 6GB DDR3 @ 1333MHz
GPU: NVIDIA GeForce 9400 256MB
RetroPie Machine (Linux Mint & RetroPie)
CPU: Intel Core2Duo @ 3.0GHz
RAM: 7GB DDR2 @ 800MHz
GPU: AMD Radeon HD 3650
https://linustechtips.com/topic/895020-laptop-problem-p/#findComment-11030960
does it stay forever on the ring or does it ever shutdown or reboot after a while of sitting on the loading ring?
does the loading ring continue to spin or does it stop?
what was the last thing to happen before this started?
did he get a blue screen or anything like that before this started?
or maybe he didn't shut it down properly, or power failure.
Install any drivers or software, just before it happend
Anything info we can get about how and when this started would help with the diagnosis
https://linustechtips.com/topic/895020-laptop-problem-p/#findComment-11031914
