So, i got a MSI Aero 1080 8gb on Christmas. When i play Fortnite my gpu usage goes up to 90% no matter what which is okay. But it’s always at 90C when I’m playinf Fortnite and when it goes up to 92 my gpu fan goes to 5400 rpm but it’s usually only at 1480. When it goes up to 92 the GPU usage goes down to around 80%. Thanks in advance :)
https://linustechtips.com/topic/894213-1080-hitting-extreme-temps/
Did not know you could measure GPU fan speed in RPM.
Your card is a blower style and is common to have high temperature.
SPECS: Intel Core i5-4460 // PowerColor Red Dragon RX 480 4GB // 1x8GB DDR3 RAM // Delta 500AB-6A PSU // HyperX Cloud Stinger / Logitech G710+ / Logitech G502 / Xbox One Halo Guardian controller // LG 24M45H 1080p //
How to cope with depression
Spoiler free review of Life is Strange (Video Game)
how's your case airflow?
"Sulit" (adj.) something that is worth it
i7 8700K 4.8Ghz delidded / Corsair H100i V2 / Asus Strix Z370-F / G.Skill Trident Z RGB 16GB 3200 / EVGA GTX 1080Ti FTW3 / ASUS ROG SWIFT PG279Q
Samsung 850 EVO 500GB & 250GB - Crucial MX300 M.2 525GB / Fractal Design Define S / Corsair K70 MX Reds / Logitech G502 / Beyerdynamic DT770 250Ohm
SMSL SD793II AMP/DAC - Schiit Magni 3 / PCPP
Old Rig
i5 2500k 4.5Ghz | Gigabyte Z68XP-UD3P | Zotac GTX 980 AMP! Extreme | Crucial Ballistix Tactical 16GB 1866MHz
hmm, ive got two of those cards and mine only go to about 3300rpm as measured in Afterburner. Blower cards will run about 10c higher than ones with aftermarket coolers on them. That seems like some pretty serious throttling. I'd grab GPUz and let it run in the background and itll let you know why and what its doing. Afterburner is great too and is what I use to monitor everything.
Shade - Silverstone Primera PM01 RGB, i7 8700k 5.0ghz all core, Gigabyte Aorus Gaming 7, Corsair H110i AIO, 32GB TridentZ@3200Mhz, 240GB PNY CS1311, 500GB 960EVO, 3x 4TB Hitachi Ultrastar NAS, 1TB Apple NVME SSD, MBest MB279QR 1440p 165hz Monitor, Shimian (Apple Reject 27" Cinema display) 1440p 60hz, TT RIING 140mm x 4, Phanteks Halos x4
ASUS ROG17 GL702VM - 17" 75hz Gsync 1080p, 500GB 960 EVO, 500gb 850 EVO, 1060 6GB Undervolted (ASUS your cooling sucks), Modded cover.
Monochrome - i7 4570, Hyper 212 EVO, 120GB Mushkin Chronos, 16GB EVGA 2400Mhz DDR3, Rx480 8GB, Enthoo Pro M
Orwell (Lenovo X1 Yoga 1st Gen? 14" 2k IPS Screen, 500gb PM851 SSD, 8GB DDR3, i7-6500u.
Lenovo X1 Yoga 3rd Gen: 14" 2k 500 nit Dolbyvision Display, 256gn NVME, 16GB DDR4, i7-8650u
Newest Acquisition:
T480 (Think Hard) - i5-8250u undervolted -130mv, 16gb DDR4 2400, upgraded display B140Han01.3, 256gb SSD
Maybe is that cheap plastic cooler. Turn up the fans or check tim.
Idk if I'd trust hue for monitoring, compared to what HwMonitor/Afterburner/OpenHwMonitor/Gpuz are reporting. Unless the models shipped at christmas came with blowers capable of another 2100rpm not sure what to say.
In any case it seems like you need to look at undervolting either on a custom curve via Ctrl-F in afterburner or lowering your power limit and increasing your clock speeds to compensate, this essentially will force your cards to run leaner at their given speeds/voltage curve. Not to mention, I'd consider changing the pretty conservative fan curve.
Newest Acquisition:
GPUZ says 5400 rpms aswell
One fan in this case would drown out both cards at 60%. Only reason one runs so hot is because of evga's bios when they slapped on the ax cooler.
But I also have airflow in the case, which could be your issue, I know on some cards the fan speed is limited, what is your percentage rather than rpm?
Airflow isn't a problem in my case... It's been fine with a gtx 1060, and even fine since I got my 1080... but at the end of january my gpu did something which idk... When I set my fan speed to 100% on MSI afterburner, the rpm is 3300. So it would be li ke 163%
Hmm, reinstall maybe? I might try emailing MSI to see if they have a whitesheet for the MSI Aero. What really bugs me about these cards is the damn DVI connector blocks like half the exhaust port making it that much harder for the card to stay cool. This card seriously needs to not have anything back there, and who is still using DVI on a 1080?
Newest Acquisition:
I still use it. Better to buy a new card then 3 new monitors.  Doubt it creates backpresure enough to effect temps. It is a blower after all.
I use the DVI for my 144hz since I don't have a HDMI 2.1 haha
