Grounding power cable
I just opened the power plug (UK) that came with my speaker set and noticed that it doesn't have a ground wire.
I'm trying to solve an issue I'm facing with humming and buzzing coming from the speakers and was just wondering if changing the cable and adding a ground wire would eliminate it.
I made this post yesterday so maybe you can find more information in it.
https://linustechtips.com/topic/893101-grounding-power-cable/
