my motherboard audio is constantly skipping. (mobo model in signature)
however, my hdmi audio via my gtx 1050 is fine... does anyone else have this issue?
She/Her
Phone: OnePlus Nord CE 5G | 128GB | 8GB Ram
Main Desktop: Ryzen 5 3600 | GTX 1060 6GB | 32GB Ram
Main Laptop: Acer Aspire V3-771G | Core i7 3612QM | 16GB
https://linustechtips.com/topic/892991-motherboard-audio-issue/
Just use your video card audio or get a USB sound adapter
Best of myself(1000th post)
Vista
Core i5-8400
8GB DDR4
GTX 1050ti
1TB 7200RPM HDD
MSI H310M PRO-VD
EVGA 450BT
Cooler Master masterbox lite 3.1
Arctic Cat
Core 2 quad q8200
8GB DDR2 ECC
GTX 550ti
1TB 7200RPM HDD
Dell precision t3400 motherboard
https://linustechtips.com/topic/892991-motherboard-audio-issue/#findComment-11008333
Tried a different driver?
Also if its skipping in video it could be a corrupt codec.
MSI MAG X670E TOMAHAWK WIFI Motherboard, AMD Ryzen 9 7900X3D Desk-top Processor (12-core/24-thread, 140MB cache, up to 5.6 GHz max boost), CORSAIR VENGEANCE DDR5 RAM 32GB (2x16GB) 6000MHz CL30 AMD EXPO iCUE Compatible Computer Memory, Samsung 990 PRO NVMe M.2 SSD, 2 TB, PCIe 4.0, 7,450 MB/s read, 6,900 MB/s write, Internal SSD, 2 x Seagate BarraCuda 4 TB Internal Hard Drive HDD – 3.5 Inch SATA 6 Gb/s 5400 RPM 256 MB Cache for Computer Desktop PC Laptop (ST4000DM004), MSI MPG A1000G PCIE5 Power Supply Unit, UK Plug - 1000W, 80 Plus Gold Certified, Fully Modular ATX 3.0, PCIe 5.0 GPU, XILENCE XC982 LQ240PRO AIO COOLER, XFX Speedster MERC 310 AMD Radeon RX 7900 XT 20GB 1 x AOC CU34G2XE & 1 x Samsung U32J59XUQ 3840 x 2160 4K, 1 x Samsung Evo 970 Evo Plus NVME PCI-E 1TB, 1 x Samsung Evo 850 250GB, 1 X Sandisk Ultra II SSD 240GB + 2 X 4TB Seagate Barracuda SATA III,  MZHOU 7 Ports PCIe USB 3.0 Card,  2 x UGREEN Hard Drive Enclosure 3.5 inch External SATA Disk Caddy Reader USB 3.0 2.5 3.5 HDD SSD 16TB UASP Case Dock Station With 12V 2A Power Adapter For Windows with 6TB Seagate Barracuda SATA III, Fractal Design Pop XL Case + 4 Fractal Design 140mm Case Fans, Logitech MX Vertical & MX Ergo Trackball Mouse using same USB unifying device, Microsoft Ergonomic Keyboard, Windows 11 Pro x64 Retail, 6TB Seagate USB 3.0 Backup Plus Hub, Blue Yeti Microphone, Logitech C922 Pro HD,  Logitech C920 Pro HD, Bit Defender Total Security 2021.
Second PC (Cyclops) - MSI 990FXA Gaming, AMD FX 8370 4Ghz, Corsair 16GB Vengeance Red 9-9-9-24 1600Mhz, Arctic Cooling Freezer 13, Asus Strix 1050TI 4GB, 1 X Acer 27" Full HD Monitor, 1 X Sandisk Ultra II SSD 240GB, 1 x Samsung Evo 850 250GB, 2 X Seagate Barracuda 2TB, 1 X WD Black 2TB, 1 x ASUS 16x DVDRW, X-Case Eagle III Case, 3 X Corsair AF 120 Case Fans, EVGA 850 G2 80+ Gold + PSU, Logitech MX Master Mouse, Corsair K30 Keyboard, Logitech C920 Webcam, R0DE NT1-A Microphone, Scarlet 212 Audio Interface (Revision 2), Windows 10 Pro X64 Retail, Bit Defender Total Security 2021, 2TB Seagate Expansion USB Hard Drive.
Third PC (Old Trustie) - Acer Aspire M3400, OEM Mainboard, AMD FX Athlon II X3 425 2.7Ghz, 16GB Corsair Value 1600Mhz Ram, OEM CPU Cooler, AMD R7 260 2GB GPU, 1 X Acer 27" Full HD Monitor, 1 X Sandisk Ultra II SSD 240GB, 2TB Samsung SATA III, 1 X OEM 16X DVDRW, 1 X Acer OEM Case, 1 X Corsair AF120 Case Can, Corsair CX500 Bronze+ CPU, Logitech MX Master Mouse, Corsair K30 Keyboard, Windows 10 Home X64 OEM, Logitech C920 Webcam, Bit Defender Total Security 2021.
Printers Include - Canon MG5750, Canon, IP8750,  Canon Pixma Mega tank G5050 & 2 X Samsung Xpress C410W.
1 X Zexrow Xbox360 Wired Game Controller.
TP Link Archer AX6000 Cable Router Wifi6 with a Virgin Media Hub 4.0 in Modem only mode running 1GB Fibre internet.
Samsung Galaxy S21+ 256GB Mobile Phone.
Internet Speed.....
https://www.speedtest.net/result/9935039193
https://linustechtips.com/topic/892991-motherboard-audio-issue/#findComment-11008364
If you really think it is an driver issue, the audio chip name (Realtek® ALC887 codec; see here) is the correct bit of information. The motherboard model is irrelevant as such (there are hundreds of motherboards but less audio chips / HW out there).
The first hit in Google: https://askubuntu.com/questions/488883/intel-hda-realtek-alc887-audio-stutter
https://linustechtips.com/topic/892991-motherboard-audio-issue/#findComment-11008415
it's skipping in both spotify and youtube in chrome.
She/Her
https://linustechtips.com/topic/892991-motherboard-audio-issue/#findComment-11008466
Im wondering whether something running in the background is causing this taking up system resources.
Have u tried disabling your antivirus for a minute just to see if it makes a difference?
Internet Speed.....
https://linustechtips.com/topic/892991-motherboard-audio-issue/#findComment-11008480
it's on Linux, so no antivirus.
and cpu usage is about 6% when it skips.
She/Her
https://linustechtips.com/topic/892991-motherboard-audio-issue/#findComment-11008598
its ok in windows?
Internet Speed.....
https://linustechtips.com/topic/892991-motherboard-audio-issue/#findComment-11008736
12 hours ago, jimkirk363 said:
its ok in windows?
yeah. i dual-boot on the machine, and in Windows it's okay...
She/Her
https://linustechtips.com/topic/892991-motherboard-audio-issue/#findComment-11009942
Then its a driver or codec issue.
Internet Speed.....
https://linustechtips.com/topic/892991-motherboard-audio-issue/#findComment-11010042
