780ti Maintenance maybe?
Solved by NowThatsDamp,
5 minutes ago, newcster2 said:So have you replaced your thermal paste or done any other modification to reach that level of performance? Or is that how the stock card has run for this many years? Perhaps there's an issue with my case cooling...
No that's how it ran on day 1 and the performance has never degraded. It does run on an open test bench, so you could check your case, but unless it's in a closed carboard box, that's probably not the issue. Case ventilation doesn't matter nearly as much as people tend to think it does.
My guess is that you got unlucky with the paste and just need a fresh squirt.
Skip to 7:20 on the first video
