Hello, I have recently been experiencing issues with my 2.5-year old custom built system (Bear in mind it is my first build). Firstly, I started getting bluescreen errors in the form of DPC_WATCHDOG_VIOLATION which seemed to disappear after reseating memory and gpu. Afterwards, the system would freeze for about 5 seconds until it rebooted. This issue still persists, although today it just froze without rebooting, but that happened several times over the span of 2 hours
Specs:
CPU: amd fx 6350 3.9ghz
GPU: nvidia gtx 1050ti
Memory: 2x Crucial ballistix sport 4gb ddr3 1600mhz (8gb)
Motherboard: asrock 980de3/u3s3
hdd: Seagate barracuda 1tb
psu: Corsair cx 430m
os: windows 8.1 64-bit
Thanks in advance for your help, Alex.
https://linustechtips.com/topic/892224-several-pc-issues/
~Moved to troubleshooting
Welcome to the forums :)
We have a NEW and GLORIOUSER-ER-ER PSU Tier List Now. (dammit @LukeSavenije stop coming up with new ones)
You can check out the old one that gave joy to so many across the land here
Computer having a hard time powering on? Troubleshoot it with this guide. (Currently looking for suggestions to update it into the context of <current year> and make it its own thread)
Computer Specs:
Mathresolvermajig: Intel Xeon E3 1240 (Sandy Bridge i7 equivalent)
Chillinmachine: Noctua NH-C14S
Framepainting-inator: EVGA GTX 1080 Ti SC2 Hybrid
Attachcorethingy: Gigabyte H61M-S2V-B3
Infoholdstick: Corsair 2x4GB DDR3 1333
Computerarmor: Silverstone RL06 "Lookalike"
Rememberdoogle: 1TB HDD + 120GB TR150 + 240 SSD Plus + 1TB MX500
AdditionalPylons: Phanteks AMP! 550W (based on Seasonic GX-550)
Letterpad: Rosewill Apollo 9100 (Cherry MX Red)
Buttonrodent: Razer Viper Mini + Huion H430P drawing Tablet
Auralnterface: Sennheiser HD 6xx
Liquidrectangles: LG 27UK850-W 4K HDR
https://linustechtips.com/topic/892224-several-pc-issues/#findComment-11000670
1 minute ago, Malakas123 said:
When playing games, specifically Overwatch.
have you had a look at temperatures?
She/Her
Phone: OnePlus Nord CE 5G | 128GB | 8GB Ram
Main Desktop: Ryzen 5 3600 | GTX 1060 6GB | 32GB Ram
Main Laptop: Acer Aspire V3-771G | Core i7 3612QM | 16GB
https://linustechtips.com/topic/892224-several-pc-issues/#findComment-11000719
Just now, deltajulietkilo said:
have you tried switching it off and on again :D:D. Like firelighter487 said check temps, the other option i would try is doing a full clean install of the gpu drivers. i had the same problem as you and it seemed to sort it for me.
I have infact re installed the nvidia drivers, no luck there.
https://linustechtips.com/topic/892224-several-pc-issues/#findComment-11000775
33 minutes ago, Malakas123 said:
Idle: CPU in the 20s, GPU in the 30s
When playing: CPU high 30s or low 40s and GPU in the high 60s or low 70s
(Celcius measurement)
that seems fine... weird..
how? with DDU?
She/Her
https://linustechtips.com/topic/892224-several-pc-issues/#findComment-11000894
