Lookinf for AMP and DAC
Ardy
So i just bought a pair of Sennheiser HD650 and i need both and amp and a dac or a combo. I wanna avoid buying something like the O2 or Schiit because the shipping from the states to europe is too expensive and it's not worth for that price range. Does anyone know of a good option from a european brand for about 200/250€?
Thanks for the help
Thanks for the help
Head n Hifi is located either in Germany or Switzerland, try buying from them : http://www.headnhifi.com/
edit: Exact link to the product http://www.headnhifi.com/o2-odac-combo
edit2: Also, Schiit has a European reseller here https://www.schiit-europe.com/
The Magni 3 (NOT Magni 2) is a pretty good amp for that asking price
https://www.schiit-europe.com/index.php/producten/amps/magni3-product-1.html
You can always start off with the Magni 3 first and use your mobo as DAC, if you're not too happy with the performance or sound of your mobo DAC, then you can always get the Modi 2.....though I seriously doubt you can hear the difference between onboard DAC vs external DAC (like the Modi 2), unless the onboard DAC is total crap to begin with.
The Modi 2 would be a nice complement to the Magni 3
https://www.schiit-europe.com/index.php/producten/dacs/modi2-usb-product-7.html
I have the HD6XX which is similar sounding to the HD650 and I love it! I have a good number of higher end cans and the HD6XX can keep up with 'em. But I do believe you need to feed the can with clean and sufficient juice for the HD6 series to shine.
Main Rig: AMD AM4 R9 5900X (12C/24T) + Tt Water 3.0 ARGB 360 AIO | Gigabyte X570 Aorus Xtreme | 2x 16GB Corsair Vengeance DDR4 3600C16 | XFX MERC 310 RX 7900 XTX | 256GB Sabrent Rocket NVMe M.2 PCIe Gen 3.0 (OS) | 4TB Lexar NM790 NVMe M.2 PCIe4x4 | 2TB TG Cardea Zero Z440 NVMe M.2 PCIe Gen4x4 | 4TB Samsung 860 EVO SATA SSD | 2TB Samsung 860 QVO SATA SSD | 6TB WD Black HDD | CoolerMaster H500M | Corsair HX1000 Platinum | Topre Type Heaven + Seenda Ergonomic W/L Vertical Mouse + 8BitDo Ultimate 2.4G | iFi Micro iDSD Black Label | Philips Fidelio B97 | C49HG90DME 49" 32:9 144Hz Freesync 2 | Omnidesk Pro 2020 48" | 64bit Win11 Pro 23H2
2nd Rig: AMD AM4 R9 3900X + TR PA 120 SE | Gigabyte X570S Aorus Elite AX | 2x 16GB Patriot Viper Elite II DDR4 4000MHz | Sapphire Nitro+ RX 6900 XT | 500GB Crucial P2 Plus NVMe M.2 PCIe Gen 4.0 (OS)2TB Adata Legend 850 NVMe M.2 PCIe Gen4x4 |  2TB Kingston NV2 NVMe M.2 PCIe Gen4x4 | 4TB Leven JS600 SATA SSD | 2TB Seagate HDD | Keychron K2 + Logitech G703 | SOLDAM XR-1 Black Knight | Enermax MAXREVO 1500 | 64bit Win11 Pro 23H2
