So what I have is a machine that I want to be able to remote into out of OS.
So imagine I have 2 PCs- I normally access pc 1 directly, but sometimes I use a low latency capture device on PC2 to get a video signal from PC1 if I need direct control.
What could I do for KB/M and other USB devices here? Some way to control from PC2. Some kind of solution that's plugged into USB on PC1 and controlled by software on PC2 or over the network. Doesn't have to be elegant, just enough to pass through some keystrokes and click on things on PC2. A virtual USB disk would be nice as well, but really I can just use PXE if I need to.
The only idea I have would be to use an arduino or something and pass commands to it, but that would be cancer and I'd have to do a lot of work to set it up. There's gotta be some kind of solution already made for this.
Ideas?
https://linustechtips.com/topic/889393-need-remote-keyboardhid-directly/
