Ok guys, so I'm working on a cyberpower prebuilt system for someone. Specs are:
Asus p6t  LGA 1366
idk cpu because i've never had it all the way booted. (possibly a 920)
dual evga GTX 280s
12GB corsair dominator memory
120mm asetek liquid cooler
windows 7 home premium
1000w psu, cant see brand.
Here's what's happened so far. I plugged it up and it booted to the windows login screen. I put in a disk to run ophcrack to find the password (so I wouldn't have to call someone). The CD is not corrupted because it worked on my desktop. I reboot it and go into the bios and then it shuts down randomly, I didn't change anything. I press the power button and it does nothing. Then I unplugged the cpu, gpu, and mobo power. I tested the psu and all the voltages were good. I cleared the CMOS and still nothing.
Since then it has turned on (by itself), ran for like 15 seconds and then shut down all by itself. I'm at a loss for what to do now. Should I take the second gpu and some of the memory out to run it as barebones as possible or did I somehow brick the bios? Thanks for your help. And I did read the sticky.
Mid 2009 Macbook Pro 2.26Ghz Core2Duo undervolted/8gb/500gb Momentus XT
HTPC i3-2100/8gb/2x500gb WD blue/PNY GT430/Silverstone LC-13b-e
https://linustechtips.com/topic/88938-cyberpower-prebuilt-help/
Without the ram too? Sorry i'm late responding. I'm not home so i'll report back later if that worked.
https://linustechtips.com/topic/88938-cyberpower-prebuilt-help/#findComment-1205182
When I woke up this morning it was running (turned on all by itself) but there's nothing on the display. Also, the radiator fan is dead so it could've been overheating.
https://linustechtips.com/topic/88938-cyberpower-prebuilt-help/#findComment-1208055
