Hey, I wanted to hear peoples preferences on thermal compounds.
Athlon X4 760K | MSI A88X-G43 | 8GB G.Skill Ripjaws 1333Mhz | MSI R7 260X 2GB | Corsair 300R | Corsair CX430 | 640GB HDD | Windows 7 64-bit
HP W2071d 20" 900p TN | Stock Dell K/B | Microsoft Comfort Optical Mouse 3000 + SteelSeries Qck Portal 2 Ed. | Grado SR80i + cheap 2.0 speakers
https://linustechtips.com/topic/8892-thermal-compound/
Theres really only a 1~2 degree difference between brands of TIM and it doesn't necessarily mean that the more expensive ones perform better just as most things in life are
I personally use MX-4 but that was just what was available to me at the cheapest price at that time
3770k, Asrock Extreme 4, 16GB Dominator Plat, AX760i, 250GB BX100, 1.5TB Seagate, Win 7 Home Prem
https://linustechtips.com/topic/8892-thermal-compound/#findComment-98963
Some TIMs have to cure, some never harden, some are conductive but work better. Just wanted to hear peoples opinions.
https://linustechtips.com/topic/8892-thermal-compound/#findComment-99436
I currently use MX-4. Easy use, good price and performance. Nothing special, but one can't go wrong with it.
Intel Core i7 3770K delidded @ 4,5Ghz | Corsair H100i w/ Noctua NF-F12s | EVGA Geforce GTX 770 2GB @ 1,2Ghz | MSI Big Bang MPower Z77 | 16GB Corsair Vengeance DDR3 1600Mhz CL9 | Windows 10 Professional 64 bit | 2TB Seagate Barracuda | 2TB Samsung | 256GB Samsung 840 Pro | Asus Xonar Essence STX | Seasonic X Series 850WLogitech MX Master | Corsair MM400 | Corsair Vengeance K70 | beyerdynamic MMX 300 Manufaktur | Asus PB278Q 27" 1440p | Corsair Obsidian 550D
https://linustechtips.com/topic/8892-thermal-compound/#findComment-99442
export PS1='\[\033[1;30m\]┌╼ \[\033[1;32m\]\u@\h\[\033[1;30m\] ╾╼ \[\033[0;34m\]\w\[\033[0;36m\]\n\[\033[1;30m\]└╼ \[\033[1;37m\]'
"All your threads are belong to /dev/null"
| 80's Terminal Keyboard Conversion | $5 Graphics Card Silence Mod Tutorial | 485KH/s R9 270X | The Smallest Ethernet Cable | Ass Pennies | My Screenfetch |
https://linustechtips.com/topic/8892-thermal-compound/#findComment-100178
TIM consultants Quantum, same performance as MX 3 but half the price.
Less than $5 for a syringe with shipping included(In the US), I usually get 3 or 4 when I order because no matter how many you buy they charge the same amount for shipping.
http://www.tim-consultants.com/matrix2.html
CPU: AMD 3950x Mobo: MSI B550 RAM: 32GB DDR4 GPU: Asus 3080 Strix PSU: Superflower Leadex 3 720w Case: BeQuiet 500DX
Storage: 2TB SSD + 4TB HDD Audio: SMSL 793ii -> HiFiman HE-400 + Mission MS-50 Speakers
https://linustechtips.com/topic/8892-thermal-compound/#findComment-100340
I swear to Noctua NT-H1 paste. It is right in the top 5 as far as temperature goes, but when you factor in the amount you get and the price for it, as well as the consistency when applying it, how looooong it lasts and the fact it reaches peak performance immediately after application, it is by far the best overall paste you can use, this is fact, trust me, I've got this down to science.
In case the moderators do not ban me as requested, this is a notice that I have left and am not coming back.
https://linustechtips.com/topic/8892-thermal-compound/#findComment-100633
Noctua NT-H1. Doesn't have to cure. Big syringes with 15 applications for as much as a tiny tube of arctic silver 5 (dunno if North America gets Noctua as cheap as EU though) - it lasts forever and the consistency is super easy to work with. It's also non-conductive and still manages to be right up there with the best in terms of thermal performance.
https://linustechtips.com/topic/8892-thermal-compound/#findComment-100635
