Hello, I'm looking for a CPU to upgrade my system. I have a MSI 970 gaming board with 16GB of ram and a GTX 950. I've ran test and the only thing holding me back is the AMD FX-6300. It's water cooled but I don't want to risk screwing up anything trying to overclock it. I was looking at a AMD FX-8370 or a AMD FX 4350, just something with a little more power and at least 4GHz. I'm not that knowledgeable on components so I thought someone here might be able to help me. It's a AM3+ socket If that helps.
https://linustechtips.com/topic/888921-need-help-finding-the-right-cpu/
3 minutes ago, green4101 said:
I just got most of the parts from a friend in august, I'm just looking for a upgrade cheaper than buying a whole new board and CPU
If you're looking for a drop-in upgrade, the 8370 is about as good as it will get on the AM3+ socket. If you can save for a couple months, sell the 6300, board and ram and get something like an r5 1400 with 8gb of ram. Would smash any FX cpu for not much more money.
8 minutes ago, hconverse02 said:
How much do you have to spend? It is probably much more worth it going to ryzen than upgrading a dead platform.
I'm just looking at this point. side note is this how I reply? It's my first time here.
Yeah you figured it out, but a good $300 would buy you into the ryzen platform, maybe a bit more because of ram prices today.
What about the FX-8350? I can find that for around $115, would that be an upgrade from my current?
It would be an upgrade, but not a brilliant one. The whole 8320/8350/8370 are all basically the same performance wise, other than a couple hundred mHz. At $115, that's not a great deal but if its all you can afford then it would be a decent upgrade
I don't know how reputable systemrequirementslab.com is but here's what it says
I've never seen that site before, so I don't really know what to say about that. If you sold the cpu and motherboard, you could possibly afford to get an i5 3570k and a z77 motherboard. This would be a massive upgrade over FX at not much expense, as you could probably get that combo for around $170, and the gaming performance would be a lot better. Or an i7 3770 (non-K) with a cheaper motherboard would set you back around the same. If not, the 8350 will be a good upgrade but $115 is a little bit steep for what it is
Upgrading in a DEAD platform isnt really worth it, Id say Jump over to Ryzen too. FX series was a disaster
Ryzen 5 1600, Gigabyte AB350N Gaming-WiFi, 16GB GeiL @ 2133Mhz,GTX 980 Founders Edition, NZXT Manta White,SuperFlower 500W GOLD, 120+1TB
HELPFUL LINKS; PSU Tier List by @STRMfrmXMN GPU OC'ing Database by @Cobalt  Water Cooling 101 by @Gmac TEAM AMD & ATi & Nvidia
