Hi, I have a GTX 1070, i5 7600k & 8gb single RAM stick. I am playing Overwatch on a 144hz monitor at EPIC settings. My fps is dropping below 144hz in big fights and my CPU is at 100%. Will getting dual channel ram (2x8gb) help me stay above 144fps as I have heard people say it makes a big difference.
Thanks in advance
https://linustechtips.com/topic/888049-will-dual-channel-help/
overclock CPU
100% CPU = CPU bottleneck
it doesn't because you have a dGPU, it'll only help when you're using the iGPU (because it's RAM would be shared with the system ram)
Ryzen 5 3600 stock | 2x16GB C13 3200MHz (AFR) | GTX 760 (Sold the VII)| ASUS Prime X570-P | 6TB WD Gold (128MB Cache, 2017)
Samsung 850 EVO 240 GB
138 is a good number.
https://linustechtips.com/topic/888049-will-dual-channel-help/#findComment-10958174
Just now, themctipers said:
overclock CPU
CPU has already been overclocked to 4.7GHz
https://linustechtips.com/topic/888049-will-dual-channel-help/#findComment-10958175
5 minutes ago, themctipers said:
overclock CPU
and aslo, are you sure about that? I have seen benchmarks where dual channel has significantly increased fps when using a dGPU
https://linustechtips.com/topic/888049-will-dual-channel-help/#findComment-10958189
im pretty sure,
then again, im complaining about gta using 100% of my CPU at 1066MHz CAS10 so lol , my system is dying image.thumb.png.311a7bb3cdddae83c2fa5882617ed14a.png
https://linustechtips.com/topic/888049-will-dual-channel-help/#findComment-10958203
