I first need to apologize for this account name, I somehow got stuck with it a while ago. Yeah.
So here's my situation. I have an EPOX 2themax EP-9NPA+SLI Socket 939 nForce 4 SLI motherboard. It's from 2005 and is the feature of my newest period accurate build. (My previous being my currently listed machine).
It has an AMD Athlon 64 FX-57 (labeled as an FX-55, but reports as an FX-57 for whatever reason, idk not complaining) and 1GB of DDR400 (to be upped to 4GB).
My graphics cards are dual nVidia GeForce GTX 7800 512MB editions as well.
If you look at the listing on Newegg: https://www.newegg.com/Product/Product.aspx?Item=N82E16813123246 you can see an oddity that was quite common on nForce 4 SLI builds. There is a jumper card in between the 16x slots that switch it from having the first slot being a 16x slot to both slots being plain 8x slots.
My issue is regardless of how I set it up, my second 7800GTX never gets detected in Windows XP. I've tried using Forceware and the plain GeForce drivers from years apart with no luck. It doesn't appear in device manager, and doesn't work with other graphics cards, or just having one in there. I have confirmed both cards work by swapping them out. I am using an SLI bridge, and it doesn't appear to be damaged in any way. Both cards are powered, and fans are spinning. My PSU (A brand new 650W Corsair unit) is perfectly fine to power both cards.
I think the problem may lie within the jumper card. If you look at the image, it's held into the slot with that plastic hook, but the hook appears to not have any real way to hold the card in. It's very loose and can wiggle around when insterted. Either way I have tried to secure it many different ways, but it still doesn't work.
There doesn't seem to be any BIOS options to change stuff around. I don't have the manual as resources for EPOX board are actually harder to find than resources for DataExpert boards.
Any help would be appreciated. If you need any more info on my setup just ask.
https://linustechtips.com/topic/887793-help-needed-with-legacy-sli-setup/
I have an Abit Fatal1ty FP In9 SLI board with nvidia 650 chipset. It has the same small board to flip when going SLI.
But that little bugger is really sitting tight like a SO DIMM Ram module.
I think the module shouldn't wiggle at all.
Main System:
Anghammarad : Asrock Taichi x570, AMD Ryzen 7 5800X @4900 MHz. 32 GB DDR4 3600, some NVME SSDs, Gainward Phoenix RTX 3070TI
System 2 "Igluna" AsRock Fatal1ty Z77 Pro, Core I5 3570k @4300, 16 GB Ram DDR3 2133, some SSD, and a 2 TB HDD each, Gainward Phantom 760GTX.
System 3 "Inskah" AsRock Fatal1ty Z77 Pro, Core I5 3570k @4300, 16 GB Ram DDR3 2133, some SSD, and a 2 TB HDD each, Gainward Phantom 760GTX.
On the Road: Acer Aspire 5 Model A515-51G-54FD, Intel Core i5 7200U, 8 GB DDR4 Ram, 120 GB SSD, 1 TB SSD, Intel CPU GFX and Nvidia MX 150, Full HD IPS display
Media System "Vio": Aorus Elite AX V2, Ryzen 7 5700X, 64 GB Ram DDR4 3200 Mushkin, 1 275 GB Crucial MX SSD, 1 tb Crucial MX500 SSD. IBM 5015 Megaraid, 4 Seagate Ironwolf 4TB HDD in raid 5, 4 WD RED 4 tb in another Raid 5, Gainward Phoenix GTX 1060
(Abit Fatal1ty FP9 IN SLI, C2Duo E8400, 6 GB Ram DDR2 800, far too less diskspace, Gainward Phantom 560 GTX broken need fixing)
Nostalgia: Amiga 1200, Tower Build, CPU/FPU/MMU 68EC020, 68030, 68882 @50 Mhz, 10 MByte ram (2 MB Chip, 8 MB Fast), Fast SCSI II, 2 CDRoms, 2 1 GB SCSI II IBM Harddrives, 512 MB Quantum Lightning HDD, self soldered Sync changer to attach VGA displays, WLAN
