7970 questions about differences between two cards
I bought two ASUS 7970 DCU2 v2 cards and there are differences between the two cards that I would like explained. One card is limited in vcore and clocks (1175mv and 1125mhz) and the other 7970 can be adjusted to 1300mv and the clocks can be pushed higher (I forget). I have checked and both cards are using the same bios.
May I ask why one card is different than the other? Is there any way I can unlock the extra vcore and clocks of the one card? Thank you
Probably BIOS values being changed that I don't think you can modify.
This but you can modify by flashing the BIOS.
Current rig: i5 4670K | GTX 670 | Asus Z87I-Pro | Silverstone Strider Plus 600W | Custom mITX case | Seagate Barracuda 3TB | Samsung 840 120GB | G430 | CM Storm Quickfire Pro - MX Red | LG 21.5"
There shouldn't be any difference AFAIK.  Just use Sapphire Trixx for OCing and you can force 1381mV on any 7970 (at least in my experience from a year ago when I had 7970's)...
Intel Core i7 4930K @ 4.7GHz | Asus Rampage IV Extreme | 2 x EVGA GTX Titan SC (1254MHz) | 16GB Patriot Viper Extreme DDR3 2133MHz (4 x 4GB) | Corsair AX1200 | Silverstone Temjin TJ11 | Corsair Force 3 240GB (System) | 2 x Intel 320 160GB SSD (Dedicated Gaming Drives) | Hitachi Deskstar 1TB (Data) | MS Windows 10 Pro | EK Supreme HF/FC-Titan/Rampage IV Extreme blocks | Hardware Labs GTX 560/240 rads | Alphacool VPP-655 D5 pump | Bitspower mod kit/pump top/fittings/120mm res
 Is there a setting in trixx that is hidden that enables this? Also what about unlocking the clocks?
True, but I meant without re-flashing it.
Are you sure you don't have something along the lines of one card being 'just' a DCU2 and the other a DCU2 OC or TOP version? Asus does bin their chips I believe.
CPU:Intel Xeon X5660 @ 4.2 GHz RAM:6x2 GB 1600MHz DDR3 MB:Asus P6T Deluxe GPU:Asus GTX 660 TI OC Cooler:Akasa Nero 3
SSD:OCZ Vertex 3 120 GB HDD:2x640 GB WD Black Fans:2xCorsair AF 120 PSU:Seasonic 450 W 80+ Case:Thermaltake Xaser VI MX OS:Windows 10
Speakers:Altec Lansing MX5021 Keyboard:Razer Blackwidow 2013 Mouse:Logitech MX Master Monitor:Dell U2412M Headphones: Logitech G430
Big thanks to Damikiller37 for making me an awesome Intel 4004 out of trixels!
Why are you using trixx ? It was very buggy with my Sapphire 7970, it also couldn't let me over-volt the VRAM.
MSI Afterburner was far easier to work with.
MSI AB will not allow me to adjust the voltage What-So-Ever with my problem card. The slider is greyed out.
I am sure that my "good" 7970 is not a TOP card. It would show up in GPU Tweak as a Top card if it was.
If you were unable to unlock the voltage through a BIOS flash nor MSI afterburner your card might be hardware locked, physically compare both cards to determine if the "problem" card is of a different revision.
It seems so weird to me that I can use Trixx to increase the clocks past 1125 and use GPU Tweak 2.2.1.4 to increase the vcore up to 1.4v BUT I can't some how either flash a bios to make this card like my other one or use just one program to OC and OV past those thresholds (1125clocks and 1175mv).
