Does anyone have a 1440p, 144/165 Hz monitor?
kingmustard
I currently have 2x identical 25" 1440p monitors 60 Hz monitors.
I want to add a high refresh rate 1440p monitor between them.
I'm hoping for the heights of them all to be as similar as possible.
However, there are hardly any (if any) 25" 1440p high refresh rate monitors.
Does anyone have any of the following?
  • Acer XB241YU (24")
  • Acer XB271HUABMIPRZ (27")
  • Acer XF240YUBMIIDPRZX (24")
  • Acer XF270HUABMIIDPRZX (27")
  • Acer XG270HUOMIDPX (27")
  • AOC AG241QG (24")
  • AOC AG241QX (24")
  • AOC AG271QX (27")
  • Asus MG278Q (27")
  • Asus MG279Q (27")
  • Dell S2417DG (24")
  • Iiyama GB2760QSU-B1 (27")
  • Samsung C27HG70 (27")
  • Zowie XL2730 (27")
  • Zowie XL2735 (27")
If so, could you possibly measure the height of the screen in two ways, for me?
  1. The height including panel casing (but not including the stand etc.)
  2. Just the panel height itself (so should be a little shorter than the above)
This would be very much appreciated, as it's very hard to get heights online!
MG279Q w/o Stand - 625 x 368 x 63 mm. That was taken from my manual, I don't actually have a tape measure accessible right now, but the bezels are approximately 1/2" on each edge. These would be the same dimensions as the MG278Q, the only difference being the 9 is IPS and the 8 isn't.
Intel Core i7 8700k | be quiet! Dark Rock 4 | Fatal1ty Z370 Gaming-ITX/ac | 32 GB G.Skill TridentZ | 256 GB Intel® SSD 600p Series | ZOTAC GeForce® GTX 1080 Ti Mini | Fractal Design Node 304 | Cooler Master V750 | Asus MG279Q | Asus VC279 | Logitech G710+ | Corsair M65 Pro RGB
Acer XB271HUbmiprz (IPS version) owner here.  I'm measuring 611mm width and 367mm height including bezels.
The height of the screen itself (top row of pixels to bottom row of pixels) is 335mm.  The side bezels are between 6 and 7mm
The original stand is height adjustable, but I don't know the exact range because I ditched the stands on mine for monitor arms.
