ok so i have a android watch NOT A WEAR just a watch that can run android apps any apps BUT ....
i want to get a custom watch face right BUT>...
i cannot get that app what you sync on your phone and that beacuse it will be too difficult to get that app on my watch yes it can run apps but its difficult ok
so is there a way to get different faces like idk exporting them >?
i mean its full  Android 5.0.2 Lollipop so it surely can somehow it just dont have google play store so i have to get apps from pcc and shit
i tried putting the google service and the playstore on it but it says shit about i cant remember but it dont let me launch it idk why but u know..
so idk anyone help me here?
if u want to know its the i am + dial watch if it helps LOL
https://linustechtips.com/topic/887485-android-wear-dev-please-help-me/
Your title is a bit misleading. You can find a small community of Android Watchface developers at https://plus.google.com/communities/109827242607524552712.
Usually with these watches what you see is what you get, with little developer support past the initial release, hence why it's still running Lollipop. Almost all watch face developers are developing for Android Wear, Apple Watch, or Fitbit. Installing the Google Play Store on a 5.0.2 smartwatch will not allow you to download watch faces designed for Android Wear.
Make sure to quote me or use @PorkishPig to notify me that you replied!
Desktop
CPU - Ryzen 9 3900X | Cooler - Noctua NH-D15 | Motherboard - ASUS TUF X570-PLUS RAM - Corsair Vengeance LPX DDR4-3200 32GB Case - Meshify C
GPU - RTX 3080 FE PSU - Straight Power 11 850W Platinum Storage - 980 PRO 1TB, 960 EVO 500GB, S31 1TB, MX500 500GB | OS - Windows 11 Pro
Homelab
CPU - Core i5-11400 | Cooler - Noctua NH-U12S | Motherboard - ASRock Z590M-ITX RAM - G.Skill Ripjaws V DDR4-3600 32GB (2x16)  | Case - Node 304
PSU - EVGA B3 650W | Storage - 860 EVO 256GB, Sabrent Rocket 4.0 1TB, WD Red 4TB (x6 in RAIDZ1 w/ LSI 9207-8i) | OS - TrueNAS Scale (Debian)
