I bought my computer pre-built from microcenter, I still regret this, and it came an awesome set up. It has:
Gigabyte Technologies GA-Z97X-Gaming GT Motherboard
Intel Core i7 4790K
NVIDIA GeForce GTX 980Ti
Corsair H110i Liquid Cooling
When I got it and starting running it under load I noticed it got really hot. I was new to the gaming computer world and thought this was normal. After having it a few years I downloaded some monitoring software to see what my temperatures were at and researched where they should be. I noticed that my CPU was fluctuating constantly between 45C and 55o C which for a liquid cooled computer shouldn't be happening. When under load it hurt to see my poor CPU reach temps of a constant 90C-100C. I came to the conclusion that my water cooler had not been working and when I installed corsair link V4 I also noticed that it didn't even register that it exists to the computer itself. I have no experience in computer building but would like to know more on how to fix these issues on my own. Please let me know what I can do to get this working so my CPU doesn't have to die anymore than it already has.
Thank You!
https://linustechtips.com/topic/887371-h110i-not-running/
is the pump connected? it should be powered via SATA connector, and the pump wire should be connected to the CPUFAN header on your motherboard, check the fans too
ASUS X470-PRO • R7 1700 4GHz • Corsair H110i GT P/P • 2x MSI RX 480 8G • Corsair DP 2x8 @3466 • EVGA 750 G2 • Corsair 730T • Crucial MX500 250GB • WD 4TB
https://linustechtips.com/topic/887371-h110i-not-running/#findComment-10951912
Prolly check that the usb dongle is actually connect. Assuming you haven’t put a new os on since then. That’s all you need aside from ensuring the fans are connected to the pump if you aren’t using the mobo’s software to control it.
https://linustechtips.com/topic/887371-h110i-not-running/#findComment-10951942
