what exactly will work (solved)
Solved by W-L,
4 minutes ago, BlueTactic said:I'm trying to figure out if a Tr4(threadripper) water block would fit on a sp3(Epyc) building a dual CPU diy server for reasons and I want to see if. can make it basically silent
so basically I want to find out if any water block can fit on the sp3 socket
If your doing a custom loop the threadripper blocks will also work with SP3 sockets.
https://www.ekwb.com/shop/ek-supremacy-evo-threadripper-edition-acetal-nickel
