Corsair cable compatibility?
Go to solution Solved by quan289,
The pinout of the AX1200 is different from the other Corsair PSUs and has it own sets of cables. You just can't get any of the cables just because it merely looks the same.
The RM850 utilized the newer "Type 3" (Gen 2) pinout, which you need to buy this kit:
http://www.corsair.com/en/power-supply-units/psu-accessories-1/professional-individually-sleeved-dc-cable-kit-type-3-generation-2-red.html
And this 24-pin:
http://www.corsair.com/en/power-supply-units/psu-accessories-1/individually-sleeved-atx-cable-24pin-generation-2-red.html
Will these cables work with a RM 850?
http://www.corsair.com/en/power-supply-units/psu-accessories-1/professional-series-gold-ax1200-individually-sleeved-modular-cables-red.html
It says it's only for an AX1200 but it seems like they would work to me.
Thanks for your time.
https://linustechtips.com/topic/88547-corsair-cable-compatibility/
Searched in their filter for red and RM series.
The original AX series had quite a bit different modular design than what they use today for AXi or RM. For example, the 24 pin is split and things like that.
PC: CPU: Intel i7-4790 MB: Gigabyte B85N RAM: Adata 4GB + Kingston 8GB SSD: Samsung 850 EVO 500GB GPU: XFX GTR RX 480 8GB Case: Advantech IPC-510 PSU: Corsair RM1000i KB: Idobao x YMDK ID75 with Outemu Silent Grey Mouse: Logitech G305 Mousepad: LTT Deskpad Headphones: AKG K240 Sextett
Phone: Sony Xperia 5 II
I saw that but that is double the price :/
My RM 850 has a split 24 pin too
And this 24-pin:
And this 24-pin:
I can't justify $100 on aesthetics so I thought I'd make sure. Thank you for the help.
