your not going to be able to get it into the slow with it screwed in.
well you might be able to leaver it in but id be worried about the first tab of the connector so id say wait till you can get a screwdriver once you get the card out should be an easy fix or did you originally insert the card when it was unscrewed?
https://linustechtips.com/topic/885307-help/page/2/#findComment-10932392
I have tried that already
https://linustechtips.com/topic/885307-help/page/2/#findComment-10932397
