What kind of UPS should I get for my build? I had one of those voltage stabilizers with my old rig but it caught fire (!) while I was gaming, it was a 1000VA model and I only had a 430w PSU
I'm looking for something to let me save my game progress and shutdown safely, 10 or 5 minutes would be enough I think
750W PSU
23'' LED monitor
that's all, rest of the stuff (stereo speakers, router, led lamp) would be connected to my current surge protector
thx
ASUS X470-PRO • R7 1700 4GHz • Corsair H110i GT P/P • 2x MSI RX 480 8G • Corsair DP 2x8 @3466 • EVGA 750 G2 • Corsair 730T • Crucial MX500 250GB • WD 4TB
https://linustechtips.com/topic/884702-ups-for-my-build/
Well what does your system draw under gaming load? 1000VA aint much. a 1350 or 1500VA would be much better suited as their invers allow higher draw.
[FS][US] Corsair H115i 280mm AIO-AMD $60+shipping
System specs:
Asus Prime X370 Pro - Custom EKWB CPU/GPU 2x360 1x240 soft loop - Ryzen 1700X - Corsair Vengeance RGB 2x16GB - Plextor 512 NVMe + 2TB SU800 - EVGA GTX1080ti - LianLi PC11 Dynamic
https://linustechtips.com/topic/884702-ups-for-my-build/#findComment-10926992
Somewhere around 500w at full load and the monitor 30w
https://linustechtips.com/topic/884702-ups-for-my-build/#findComment-10927078
1500VA or larger is what you want.
System specs:
https://linustechtips.com/topic/884702-ups-for-my-build/#findComment-10927101
