obs not starting output?
Go to solution Solved by AlTech,
@stanmarsh19 In this first log, this is the only potentially troublesome part I found:
Quote
10:35:14.668: Required module function 'obs_module_load' in module '../../obs-plugins/64bit/chrome_elf.dll' not found, loading of module failed
10:35:14.672: [CoreAudio encoder]: Adding CoreAudio AAC encoder
10:35:14.673: [AMF] Encountered Exception during AMF initialization: Unable to load 'amfrt64.dll', error code 126.
10:35:14.674: Failed to initialize module 'enc-amf.dll'
10:35:14.681: Required module function 'obs_module_load' in module '../../obs-plugins/64bit/libcef.dll' not found, loading of module failed
10:35:14.682: Required module function 'obs_module_load' in module '../../obs-plugins/64bit/libEGL.dll' not found, loading of module failed
10:35:14.682: Required module function 'obs_module_load' in module '../../obs-plugins/64bit/libGLESv2.dll' not found, loading of module failed
10:35:14.683: Failed to load 'en-US' text for module: 'obs-browser.dll'
10:35:14.683: [browser_source: 'Version: 1.29.0']
10:35:14.685: NVENC supported
10:35:14.757: Couldn't find VLC installation, VLC video source disabled
10:35:14.761: No blackmagic support
So, perhaps re-install OBS? Cos it looks like it's missing the OBS Browser Plugin.
1 minute ago, stanmarsh19 said:
i did all it said and its still not working
What version of OBS are you using, what are your Specs and what OS are you using?
Oh and could you attach the log file from OBS as well?
Thanks.
Judge a product on its own merits AND the company that made it.
How to setup MSI Afterburner OSD | How to make your AMD Radeon GPU more efficient with Radeon Chill | (Probably) Why LMG Merch shipping to the EU is expensive
Oneplus 6 (Early 2023 to present) | HP Envy 15" x360 R7 5700U (Mid 2021 to present) | Steam Deck (Late 2022 to present)
Mid 2023 AlTech Desktop Refresh - AMD R7 5800X (Mid 2023), XFX Radeon RX 6700XT MBA (Mid 2021), MSI X370 Gaming Pro Carbon (Early 2018), 32GB DDR4-3200 (16GB x2) (Mid 2022
Noctua NH-D15 (Early 2021), Corsair MP510 1.92TB NVMe SSD (Mid 2020), beQuiet Pure Wings 2 140mm x2 & 120mm x1 (Mid 2023),
https://linustechtips.com/topic/884571-obs-not-starting-output/#findComment-10925451
1 minute ago, Dutch-stoner said:
I have my doubts... "looked all around". While you've got ~5 minutes between messages. Just use google to figure out where the log files should be located, so other people can try to help you propperly.
here we have an example of someone who takes stuff way too seriously.
https://linustechtips.com/topic/884571-obs-not-starting-output/#findComment-10925469
You were having an issue. Someone requested information, which you didn't fully supply. Pointed out you weren't investing time into the problem while other people would try to invest their time. (not fair at all?!?)
I also pointed out how you could find your log files, so trying to help you out there. (I don't use OBS, I don't know how it works, I can't help you at all other then providing you information and/or tips to gather all the requested information)
EDIT: forgot to ask: why do you say I take things way to serious?
https://linustechtips.com/topic/884571-obs-not-starting-output/#findComment-10925478
well i have posted the logs now so. is it fair now???????
https://linustechtips.com/topic/884571-obs-not-starting-output/#findComment-10925480
Quote
https://linustechtips.com/topic/884571-obs-not-starting-output/#findComment-10925484
ahh. i will try that. give me couple minutes and i will update
https://linustechtips.com/topic/884571-obs-not-starting-output/#findComment-10925488
Also,I suggest that you update to Windows 10 Build 16299 since Windows 10 Build 14393 (what you're using) will no longer be supported in March.
https://linustechtips.com/topic/884571-obs-not-starting-output/#findComment-10925495
On 1/11/2018 at 3:49 AM, Dutch-stoner said:
-snip-
sorry for seeming hateful i just was trying to look around so i said i didn't find them and i kept looking around to keep AluminiumTech from not waiting so long for a reply...
okay
May you also recommend some good settings for good 1080p 60fps video without grain or like ya know, the video becoming 2 pixels when moving slightly ingame?
https://linustechtips.com/topic/884571-obs-not-starting-output/#findComment-10925497
If you're using NVENC, the result will look worse than using a different encoder such as x264 or x265 (although both of those are ridiculously CPU demanding).
If you want to stick with NVENC then maybe increase the bitrate. The higher the bitrate the larger your file sizes should be and the better the quality should be. I wouldn't recommend anything beyond 50Mbit/s for NVENC or any other codec.
So I'd recommend trying out 30Mbit/s, then 40Mbit/s and then 50Mbit/s and then see which one you're happy with and use that.
https://linustechtips.com/topic/884571-obs-not-starting-output/#findComment-10925527
okay
https://linustechtips.com/topic/884571-obs-not-starting-output/#findComment-10925543
okay
Remember to mark as solved.
https://linustechtips.com/topic/884571-obs-not-starting-output/#findComment-10925553
