Sata power cable
Solved by W-L,
1 minute ago, Sirjfc said:Hi,
I plan to purchase a Silverstone Fan Hub to operate a few more fans. From the Silverstone website > Feature Photos, it states that it requires SATA power cables.
http://silverstonetek.com/product.php?pid=526&area=en
My SSD also uses SATA, but it does not look like the picture above. How do I power the fan hub?
Thanks
That's sata power you plug it into the sata power from the PSU same as used for the drives. Just note for the fan hub you must use 4 pin PWM capable fans if you want to control the speed of them.
