What is postcode 41 in your motherboard manual and what are your system specs.
Intel Core i7 8700k | be quiet! Dark Rock 4 | Fatal1ty Z370 Gaming-ITX/ac | 32 GB G.Skill TridentZ | 256 GB Intel® SSD 600p Series | ZOTAC GeForce® GTX 1080 Ti Mini | Fractal Design Node 304 | Cooler Master V750 | Asus MG279Q | Asus VC279 | Logitech G710+ | Corsair M65 Pro RGB
https://linustechtips.com/topic/883858-wont-post/#findComment-10917876
The normal troubleshooting rules apply-
Remove all but 1 stick of ram.
If your CPU has integrated graphics, remove the GPU.
Removal all bu the boot drive.
see if it posts.  If it does, add back one thing at a time till you find the culprit.
https://linustechtips.com/topic/883858-wont-post/#findComment-10917918
26 minutes ago, Hayashi said:
Presumably "OEM post memory initialization codes", it's an Asus board with Zotac cards and everything on water.
usually that's a improperly seated RAM module. removing it and reseating it can sometimes solve the issue.
did you OC the RAM? Did it boot properly afterwords?
[FS][US] Corsair H115i 280mm AIO-AMD $60+shipping
System specs:
Asus Prime X370 Pro - Custom EKWB CPU/GPU 2x360 1x240 soft loop - Ryzen 1700X - Corsair Vengeance RGB 2x16GB - Plextor 512 NVMe + 2TB SU800 - EVGA GTX1080ti - LianLi PC11 Dynamic
https://linustechtips.com/topic/883858-wont-post/#findComment-10917977
2 minutes ago, Hayashi said:
I didn't touch the RAM at all, still won't boot.
Did you remove and reseat the ram? How many ram sticks do you have?
https://linustechtips.com/topic/883858-wont-post/#findComment-10918010
Just now, Hayashi said:
Four, Corsair Dominator Platinums.
And you followed these troubleshooting steps?
Screens just blank, can't even flash it.
Reset the CMOS (resets BIOS), don't flash the BIOS.
https://linustechtips.com/topic/883858-wont-post/#findComment-10918038
I will, taking a break right now. Been doing it all day and need a break.
Ok, did you do a post-check before you water-cooled everything?
https://linustechtips.com/topic/883858-wont-post/#findComment-10918069
33 minutes ago, Hayashi said:
I did, it booted just fine.
Oh geez, you did a custom loop and this happened even after doing a test post?
That's really bad luck man. Sorry to hear that.
Try everything easy to get at first I guess.
It's probably something not seated right like others were saying like the ram. You need to remove stuff and plug it back in. The cables too. If it posted before hand and there has been no water or physical damage, it's definitely something like that.
https://linustechtips.com/topic/883858-wont-post/#findComment-10918202
15 minutes ago, stateofpsychosis said:
I'd try that ram stick again. It probably just wasn't seated right. Don't chuck it right away thinking it's no good ;)
I feel it's an issue with the cables and PSU won't boot with my custom sleeved extensions so stuck with the stock ones.
https://linustechtips.com/topic/883858-wont-post/#findComment-10922726
Wait, didn't you just say it started working after removing a ram module?
I'm confused now.
Did you try switching those cables at the same time or something?
https://linustechtips.com/topic/883858-wont-post/#findComment-10922736
