I am trying to overclock my i5 2500k to 4.6 but i everytime i use prime 95 i always get a blue screen like 1 minute of running it,im trying to find out why its doing it.I dont think it over heats because on core temp its in the 40's.
mobo:MSI z77-gd55
ram:GSkill Ripjaws 1333
psu:Corsair TX750
Mobo settings:
cpu ratio-4.6
vcore-1.355
internal pll voltage disabled
intel turbo boost disabled
enhanced turbo disabled
spred spectrum disabled
EIST enabled
C1E support disabled
intel C state enable
overspeed protection enabled
2500k 4.0ghz,GTX 1070 oc,MSI Z77A-GD55,G.SKILL Ripjaws(4 x 2GB)DDR3 1333,OCZ Arc 100 240gb,Samsung Spinpoint F3 1TB,Corsair TX 750w v1,CoolerMaster HAF 912,Hyper 212 EVO
https://linustechtips.com/topic/8838-help-with-2500k-oc/
First, i woukd like to say that i am not an expert when it comes to overclocking.
The blue screen could mean that the application crashed because you have an unstable overclock. You may be able to test it at different voltages and see if that helps. Your overclock might be different than someone else's because each CPU is different. If this doesn't work you may have to turn down the frequency.
I hope that this helps :)
PC Specs: Intel Core i5 3570k @4.0 GHz - Asus P8Z77-V - Corsair H60 - 16 GB Corsair Vengeance 1600 MHz - 2x EVGA Nvidia Geforce GTX 670 FTW - 120 GB Corsair Force Series 3 SSD - 1 TB Seagate Barracuda 7200 RPM HDD - NZXT Phantom 410 Black - Cooler Master Silent Pro 850w
https://linustechtips.com/topic/8838-help-with-2500k-oc/#findComment-98131
How should i configure my ram beacause I dont think it can be ocerclocked and If I use the oc genie button it goes to 4.2 on 1.350,so should I rise the vcore
https://linustechtips.com/topic/8838-help-with-2500k-oc/#findComment-98142
I would say so
Just research and find a good voltage to make sure that it will not damage your CPU and ruin its lifespan
https://linustechtips.com/topic/8838-help-with-2500k-oc/#findComment-98144
how much vcore should i go up because i don't want to burn my chip
https://linustechtips.com/topic/8838-help-with-2500k-oc/#findComment-98146
https://linustechtips.com/topic/8838-help-with-2500k-oc/#findComment-98148
After some research I see others saying 1.35V, however I have seen others say to set the voltage at auto on msi boards. I would try it on auto.
https://linustechtips.com/topic/8838-help-with-2500k-oc/#findComment-98150
was that on z77 boards?
I think on z68. I am probably not the best person to ask about overclocking. If you search for i5 2500k overclock like I did, you may be able to find some voltages that will be safe to use when overclocking to 4.6
https://linustechtips.com/topic/8838-help-with-2500k-oc/#findComment-98164
what are the temps for you cpu? idle temps and the temp for right when you turn on prime 95.
Ryzen 9 5900x | x570 TUF Gaming Pro Wifi | 32gb GSkill 4x8gb @3000mhz CL15 | ASUS Strix RX480 8gb | XFX 750W psu | Cosair H100i GTX | Fractal Design R5
Drop ENTR Halo True | Logitech G900 Choas Spectrum | Blue-Yeti | AKG k553 Pro
https://linustechtips.com/topic/8838-help-with-2500k-oc/#findComment-98182
firstly disable EIST
disable intel c state
enable the pll voltage to around 1 volt
then try from there
MB: Gigabyte Auros Gaming 7 Z370 Cpu: Intel i7 8700K @ 4.8ghz Gpu: Gigabyte GeForce GTX 1080 G1 Gaming OC 8GB Ram: Corsair Vengeance LPX 64GB DDR4 DRAM 2400MHz  Psu: Corsair RM1000i
Ssd's: WD Green nvme m.2 512gb (boot), 480gb (Steam), 480gb (Uplay) and 480gb (Origin)  Cooling: Corsair Hydro Series H115i 280mm
 Case: Corsair Obsidian Series 900D Monitors 1: Asus pb287q @ 75hz
https://linustechtips.com/topic/8838-help-with-2500k-oc/#findComment-98379
I Changed it to 4.5ghz and now it doesnt blue screen
http://imgur.com/xVdDvoY
https://linustechtips.com/topic/8838-help-with-2500k-oc/#findComment-98759
the max it hits is 70 c
https://linustechtips.com/topic/8838-help-with-2500k-oc/#findComment-98777
well it blue screen after an hour,would it need more power,I put 1.350 vcore
https://linustechtips.com/topic/8838-help-with-2500k-oc/#findComment-98778
its not stable on 4.4 or 4.5
but it hasnt crashed yet on 4.3 with vcore 1.300 but on cpuz it says its only using 1.280.
https://linustechtips.com/topic/8838-help-with-2500k-oc/#findComment-99870
MY 2500k can go up to 4.7 on 1.5v on my Z77-UD3H
Corsair 600T White | Gigabyte Z77-UD3H | Intel Core i5-2500k | 8GB Gskill Ares@1600MHz | Gigabyte G1 GTX970 | OCZ ZT 550 | Western Digital Caviar Blue 500GB | Western Digital Caviar Black 1TB | Samsung 840 EVO 250GB (boot) | Full Custom Loop | NZXT HUE
https://linustechtips.com/topic/8838-help-with-2500k-oc/#findComment-99884
of course you can get that high with that voltage but i dont want to fry my chip
https://linustechtips.com/topic/8838-help-with-2500k-oc/#findComment-99925
