i am having an issue where my screen will flicker black. it usually happens when changing between you tube videos but will happen occasionally at random spots. i took an on display video using geforce expierience and there is no scrren flicker there. here is that video
 i then took a video with my phone and you can see it. here is that video.
  i have no idea what the problem could be. i tried switching the hdmi cord with no success. any suggestions?
https://linustechtips.com/topic/883480-screen-flickering-problem/
I've been noticing screen flickering, but it seems to be a random, and this was after i installed GFE, so it might be the overlay causing problems. not too sure...
CPU: AMD R7 5800X | CPU Cooler: Corsair H115i PRO | Motherboard: MSI B550-A PRO | Memory: G.Skill RIPJAWS V DDR4 3200mhz 64GB | GPU: EVGA RTX 3080Ti FTW3 Ultra | PSU: Seasonic Prime 1300w | OS Drive: Samsung 850 EVO SSD 500GB | Games Drive: Samsung 850 EVO SSD 1TB | Media Drive: 2x WD Blue HDD 1TB in Raid 0 | Media Drive: 2x WD Black HDD 2TB in Raid 1 | Case: Corsair Obsidian 750D | Monitor 1: ASUS PB287Q UHD | Monitor 2: ASUS PG278Q WQHD
