ML 120 or silentwings 3 for front radiator?
18 hours ago, isaac22701 said:I'm looking for new fans for my h100i since the stock fans get crazy loud and my graphics card temps get really high. I have a front radiator and I was wondering if it would be better to use the ml 120s or Silentwings 3 for the radiator. I like having a quiet computer, and I have a few questions about these fans.
1. Are the BeQuiet fans significantly quieter than the Corsair fans? The Amazon page suggests they are but someone's opinion would mean more to me.
2. Is the performance of the Silentwings better to where it would be worth spending the extra 8-10 dollars for the 2 fans?
3. Would I see any noticeable improvement in gpu temperatures? This isn't a huge problem and I'm not throttling, but it is uncomfortable that even basic games drive up the temperatures to 80+ degrees (rx 480 strix)
The case is a p400s. If you need any other information about the computer the specs should be on the profile.
I have both and I have fully tested them, this is all based off my own testing.
- Silent Wings 3 & ML Pros are both very quiet. With SW3 being slightly quieter but at a reduced performance.
- Silent Wings 3 PWM version have issues with certain Fan controllers and fan headers.
- Silent Wings 3 also have gaps between each fan which creates dead spots on the radiator.
- ML Pros push allot more CFM through compared to SW3.
- ML Pro's use Magnetic Levitation technology, You will never hear the motor on Corsair Fans.
In the end ML Pro's are better for radiators.
9 hours ago, Chiru said:
You dont need static pressure fans for radiators. Best is airflow fan with decent static pressure.
I think your confused on what static pressure fans are designed for and how they operate with radiators.
