Yeah let's hook you up with some parts.
CPU: Intel - Core i3-8350K 4.0GHz Quad-Core Processor  ($177.59 @ OutletPC)
CPU Cooler: CRYORIG - H7 49.0 CFM CPU Cooler  ($29.90 @ Newegg Marketplace)
Motherboard: Gigabyte - Z370 AORUS GAMING WIFI (rev. 1.0) ATX LGA1151 Motherboard  ($100.98 @ Newegg)
Memory: Team - Vulcan 8GB (2 x 4GB) DDR4-3000 Memory  ($89.99 @ Newegg)
Storage: ADATA - Ultimate SU800 128GB 2.5" Solid State Drive  ($48.50 @ Amazon)
Storage: Western Digital - RE4 1TB 3.5" 7200RPM Internal Hard Drive  ($42.88 @ Amazon)
Video Card: Asus - GeForce GTX 1050 Ti 4GB Phoenix Video Card  (Purchased For $0.00)
Case: Cooler Master - MasterBox 5 (White) ATX Mid Tower Case  ($49.99 @ Newegg)
Power Supply: Corsair - TXM Gold 550W 80+ Gold Certified Semi-Modular ATX Power Supply  ($52.98 @ Newegg)
Total: $592.81
Generated by PCPartPicker 2018-01-06 23:51 EST-0500
I'm honestly surprised that I pulled it off but you get an overclockable quad core (competing with the 7600K) and all the premium stuff that comes with a decent computer like an SSD and a really good Power Supply.
If I was going to build a computer from scratch I'd get a more powerful GPU eschewing the 8350K, but since you already bought this is a pretty good option.
We have a NEW and GLORIOUSER-ER-ER PSU Tier List Now. (dammit @LukeSavenije stop coming up with new ones)
You can check out the old one that gave joy to so many across the land here
Computer having a hard time powering on? Troubleshoot it with this guide. (Currently looking for suggestions to update it into the context of <current year> and make it its own thread)
Computer Specs:
Mathresolvermajig: Intel Xeon E3 1240 (Sandy Bridge i7 equivalent)
Chillinmachine: Noctua NH-C14S
Framepainting-inator: EVGA GTX 1080 Ti SC2 Hybrid
Attachcorethingy: Gigabyte H61M-S2V-B3
Infoholdstick: Corsair 2x4GB DDR3 1333
Computerarmor: Silverstone RL06 "Lookalike"
Rememberdoogle: 1TB HDD + 120GB TR150 + 240 SSD Plus + 1TB MX500
AdditionalPylons: Phanteks AMP! 550W (based on Seasonic GX-550)
Letterpad: Rosewill Apollo 9100 (Cherry MX Red)
Buttonrodent: Razer Viper Mini + Huion H430P drawing Tablet
Auralnterface: Sennheiser HD 6xx
Liquidrectangles: LG 27UK850-W 4K HDR
https://linustechtips.com/topic/882748-new-build-planning-help/#findComment-10907599
Here's a build for less that will game as well though
CPU: AMD - Ryzen 5 1600 3.2GHz 6-Core Processor  ($196.97 @ OutletPC)
Motherboard: ASRock - AB350 Pro4 ATX AM4 Motherboard  ($56.98 @ Newegg)
Total: $538.29
Generated by PCPartPicker 2018-01-06 23:54 EST-0500
Computer Specs:
https://linustechtips.com/topic/882748-new-build-planning-help/#findComment-10907600
Total: $592.81
Thank you!
https://linustechtips.com/topic/882748-new-build-planning-help/#findComment-10909017
Memory: G.Skill - Aegis 8GB (1 x 8GB) DDR4-3000 Memory  ($95.99 @ Newegg)
Storage: SanDisk - Ultra 3D 250GB 2.5" Solid State Drive  ($79.99 @ Best Buy)
Storage: Toshiba - 1TB 3.5" 7200RPM Internal Hard Drive  ($42.19 @ OutletPC)
Case: Cooler Master - MasterBox Lite 5 RGB ATX Mid Tower Case  ($53.98 @ Newegg)
Total: $579.08
Generated by PCPartPicker 2018-01-07 10:23 EST-0500
https://linustechtips.com/topic/882748-new-build-planning-help/#findComment-10909040
Total: $579.08
I like how this processor is a 6 core for just a little bit more
https://linustechtips.com/topic/882748-new-build-planning-help/#findComment-10909083
1 hour ago, alex_jenkins00 said:
I like how this processor is a 6 core for just a little but more
The Ryzen 5 1600 is going to be better for productivity tasks due to its 6 cores with SMT, but the i3-8350K is unrivaled in gaming performance (not that you'll notice with a 1050 Ti, so maybe that'll tip you over to the Ryzen 5).
I disagree with herman's choice of case though :P It's not very good at cooling the inside components especially in comparison to its less priced but higher end Masterbox 5 (no lite) cousin: https://pcpartpicker.com/product/zMVBD3/cooler-master-masterbox-5-white-atx-mid-tower-case-mcx-b5s2-wwnn-01
Computer Specs:
https://linustechtips.com/topic/882748-new-build-planning-help/#findComment-10909349
I'd like to do i a bit of light streaming as well as gaming. I think I'll go with Ryzen.
https://linustechtips.com/topic/882748-new-build-planning-help/#findComment-10910248
the 1600 will perform better omce you go 1070 and above, 4 cores with no HT just doesn't cut it.
https://linustechtips.com/topic/882748-new-build-planning-help/#findComment-10910454
I'm saying what I'm saying because of this review
http://www.tomshardware.com/reviews/intel-core-i3-8350k-cpu,5304.html
There's not a lot of games in there but mostly the 8350K is beating the Ryzen 5 (not by a shit ton mind you but by a measurable margin). The 8350K is outperforming older i5s (even the 7600K) according to their last graph, though only when overclocked to 5GHz which should be doable
Interesting to say that in Hitman the Coffee i5s do take the performance crown with their 6 very fast cores.
Computer Specs:
https://linustechtips.com/topic/882748-new-build-planning-help/#findComment-10910722
So how does this build look?
https://pcpartpicker.com/user/alex_jenkins00/saved/TJXpbv
CPU: AMD - Ryzen 5 1600 3.2GHz 6-Core Processor  ($199.95 @ Amazon)
Thermal Compound: Arctic Silver - 5 High-Density Polysynthetic Silver 3.5g Thermal Paste  ($5.95 @ Newegg)
Motherboard: ASRock - AB350 Pro4 ATX AM4 Motherboard  ($76.98 @ Newegg)
Memory: *G.Skill - Aegis 8GB (1 x 8GB) DDR4-3000 Memory  ($95.99 @ Newegg)
Storage: Samsung - 850 EVO-Series 250GB 2.5" Solid State Drive  ($89.99 @ Newegg)
Storage: Seagate - Barracuda 2TB 3.5" 7200RPM Internal Hard Drive  ($59.99 @ Amazon)
Video Card: Asus - GeForce GTX 1050 Ti 4GB Dual Video Card  (Purchased For $0.00)
Case: Cooler Master - MasterBox 5 (White) ATX Mid Tower Case  ($59.99 @ Newegg)
Power Supply: Corsair - TXM Gold 550W 80+ Gold Certified Semi-Modular ATX Power Supply  ($69.99 @ Amazon)
Total: $658.83
https://linustechtips.com/topic/882748-new-build-planning-help/#findComment-10911329
Total: $658.83
no need for thermal paste, the stock cooler has it included.
https://linustechtips.com/topic/882748-new-build-planning-help/#findComment-10911456
