I have just installed Ubuntu 17.10 on my workstation PC. It is a mostly stock Dell Optiplex 330 (which i know is insanely old) but my gpu is a Nvidia Geforce GT 730. And I have been experiencing random crashes ever since I installed the card. Any ideas why? If you need any log, ask and I'll skim them of any personal info and post them.
Keep in mind these and desktop freezes not crashes, audio continues playing just fine and the cursor will intermittently move, but no desktop objects are updated. The kernel is still intact in this condition since the SysRQ requests work. My system usually isn't under any type of load during these freezes.
https://linustechtips.com/topic/882698-random-system-freezes/
What is the power supply capacity and what does the motherboard say is the max power that can be delivered by the PCIe slot?
Intel Core i7 8700k | be quiet! Dark Rock 4 | Fatal1ty Z370 Gaming-ITX/ac | 32 GB G.Skill TridentZ | 256 GB Intel® SSD 600p Series | ZOTAC GeForce® GTX 1080 Ti Mini | Fractal Design Node 304 | Cooler Master V750 | Asus MG279Q | Asus VC279 | Logitech G710+ | Corsair M65 Pro RGB
https://linustechtips.com/topic/882698-random-system-freezes/#findComment-10907162
305W Power supply and I am unsure where to look to find out the PCIe max volatge / Wattage.
https://linustechtips.com/topic/882698-random-system-freezes/#findComment-10909628
Did you install Nvidia drivers? Uninstall old drivers? Is your 730 the DDR5 or DDR3 version and does it have 1gb or 2gb of VRAM
https://linustechtips.com/topic/882698-random-system-freezes/#findComment-10909946
I installed the latest Nvidia proprietary drivers. I think they are like 387 but I'm away from the PC right now. It is the ddr5 version with 2gb vram
https://linustechtips.com/topic/882698-random-system-freezes/#findComment-10911399
Hmmm, it is possible that if you have the DDR3 version that you may be pulling too much power than your motherboard could supply, but the DDR5 version has a power draw of 25 watts, well within what the manual says is possible. It may be the power supply is just too weak to power it. Nvidia recommends a 300W PSU for it, and you have a 305, but if it's older, it's possible that the PSU is simply inefficient. The GT 710 pulls less power, but not by much. It may be time to look through the error logs.
https://linustechtips.com/topic/882698-random-system-freezes/#findComment-10911416
Okay I can do that. What logs should I look through? Xorg, kernel, or another? Also any specifics to point out. I do have a feeling your right though. I looked through the kernel log and right at the time of the freeze it has a lot of "NVIDIA-GPU" monitors disconnecting and reconnecting errors. I'm gonna add logs in a sec..
EDIT: Logs got wiped for being too old, gonna wait for next freeze then update.
Edited by laughingtnt
https://linustechtips.com/topic/882698-random-system-freezes/#findComment-10915735
Okay got a crash and got some logs. Syslog is pointing to Xorg so I'm gonna post both logs.
Syslog:
Jan 10 19:00:02 ryan-pc rsyslogd: [origin software="rsyslogd" swVersion="8.16.0" x-pid="731" x-info="http://www.rsyslog.com"] rsyslogd was HUPed
Jan 10 19:00:16 ryan-pc anacron[712]: Job `cron.daily' terminated
Jan 10 19:00:16 ryan-pc anacron[712]: Normal exit (1 job run)
Jan 10 19:00:45 ryan-pc kernel: [  366.761791] perf: interrupt took too long (2502 > 2500), lowering kernel.perf_event_max_sample_rate to 79750
Jan 10 19:01:11 ryan-pc gnome-shell[1453]: cogl-sampler-cache.c:200: GL error (1280): Invalid enumeration value
Jan 10 19:01:11 ryan-pc gnome-shell[1453]: message repeated 5 times: [ cogl-sampler-cache.c:200: GL error (1280): Invalid enumeration value]
Jan 10 19:01:15 ryan-pc google-chrome.desktop[2243]: [2243:2281:0110/190115.414595:ERROR:service_manager.cc(157)] Connection InterfaceProviderSpec prevented service: content_renderer from binding interface: blink::mojom::ReportingServiceProxy exposed by: content_browser
Jan 10 19:02:28 ryan-pc kernel: [  469.059623] perf: interrupt took too long (3144 > 3127), lowering kernel.perf_event_max_sample_rate to 63500
Jan 10 19:02:28 ryan-pc /usr/lib/gdm3/gdm-x-session[1782]: (--) NVIDIA(GPU-0): EMA e15t4 (CRT-0): connected
Jan 10 19:02:28 ryan-pc /usr/lib/gdm3/gdm-x-session[1782]: (--) NVIDIA(GPU-0): EMA e15t4 (CRT-0): 400.0 MHz maximum pixel clock
Jan 10 19:02:28 ryan-pc /usr/lib/gdm3/gdm-x-session[1782]: (--) NVIDIA(GPU-0): DELL 1800FP (DFP-0): connected
Jan 10 19:02:28 ryan-pc /usr/lib/gdm3/gdm-x-session[1782]: (--) NVIDIA(GPU-0): DELL 1800FP (DFP-0): Internal TMDS
Jan 10 19:02:28 ryan-pc /usr/lib/gdm3/gdm-x-session[1782]: (--) NVIDIA(GPU-0): DELL 1800FP (DFP-0): 330.0 MHz maximum pixel clock
Jan 10 19:02:28 ryan-pc /usr/lib/gdm3/gdm-x-session[1782]: (--) NVIDIA(GPU-0): DFP-1: disconnected
Jan 10 19:02:28 ryan-pc /usr/lib/gdm3/gdm-x-session[1782]: (--) NVIDIA(GPU-0): DFP-1: Internal TMDS
Jan 10 19:02:28 ryan-pc /usr/lib/gdm3/gdm-x-session[1782]: (--) NVIDIA(GPU-0): DFP-1: 165.0 MHz maximum pixel clock
Xorg log:
[    39.973] (--) Log file renamed from "/var/log/Xorg.pid-1341.log" to "/var/log/Xorg.0.log"
[    39.974]
X.Org X Server 1.19.5
Release Date: 2017-10-12
[    39.974] X Protocol Version 11, Revision 0
[    39.974] Build Operating System: Linux 4.4.0-97-generic x86_64 Ubuntu
[    39.974] Current Operating System: Linux ryan-gaming-pc 4.13.0-25-generic #29-Ubuntu SMP Mon Jan 8 21:14:41 UTC 2018 x86_64
[    39.974] Kernel command line: BOOT_IMAGE=/boot/vmlinuz-4.13.0-25-generic root=UUID=1e125331-a4ef-4c26-99c8-448b042f6cfb ro quiet splash vt.handoff=7
[    39.974] Build Date: 15 October 2017  05:51:19PM
[    39.974] xorg-server 2:1.19.5-0ubuntu2 (For technical support please see http://www.ubuntu.com/support)
[    39.974] Current version of pixman: 0.34.0
[    39.974]     Before reporting problems, check http://wiki.x.org
    to make sure that you have the latest version.
[    39.974] Markers: (--) probed, (**) from config file, (==) default setting,
    (++) from command line, (!!) notice, (II) informational,
    (WW) warning, (EE) error, (NI) not implemented, (??) unknown.
[    39.974] (==) Log file: "/var/log/Xorg.0.log", Time: Wed Jan 10 18:55:17 2018
[    40.039] (==) Using system config directory "/usr/share/X11/xorg.conf.d"
[    40.076] (==) No Layout section.  Using the first Screen section.
[    40.076] (==) No screen section available. Using defaults.
[    40.076] (**) |-->Screen "Default Screen Section" (0)
[    40.076] (**) |   |-->Monitor "<default monitor>"
[    40.094] (==) No monitor specified for screen "Default Screen Section".
    Using a default monitor configuration.
[    40.094] (==) Automatically adding devices
[    40.094] (==) Automatically enabling devices
[    40.094] (==) Automatically adding GPU devices
[    40.094] (==) Automatically binding GPU devices
[    40.094] (==) Max clients allowed: 256, resource mask: 0x1fffff
[    40.094] (WW) The directory "/usr/share/fonts/X11/cyrillic" does not exist.
[    40.094]     Entry deleted from font path.
[    40.094] (WW) The directory "/usr/share/fonts/X11/100dpi/" does not exist.
[    40.094] (WW) The directory "/usr/share/fonts/X11/75dpi/" does not exist.
[    40.094] (WW) The directory "/usr/share/fonts/X11/100dpi" does not exist.
[    40.094] (WW) The directory "/usr/share/fonts/X11/75dpi" does not exist.
[    40.094] (==) FontPath set to:
    /usr/share/fonts/X11/misc,
    /usr/share/fonts/X11/Type1,
    built-ins
[    40.094] (==) ModulePath set to "/usr/lib/x86_64-linux-gnu/xorg/extra-modules,/usr/lib/xorg/extra-modules,/usr/lib/xorg/modules"
[    40.094] (II) The server relies on udev to provide the list of input devices.
    If no devices become available, reconfigure udev or disable AutoAddDevices.
[    40.094] (II) Loader magic: 0x556701366020
[    40.094] (II) Module ABI versions:
[    40.095]     X.Org ANSI C Emulation: 0.4
[    40.095]     X.Org Video Driver: 23.0
[    40.095]     X.Org XInput driver : 24.1
[    40.095]     X.Org Server Extension : 10.0
[    40.095] (++) using VT number 1
[    40.102] (II) systemd-logind: took control of session /org/freedesktop/login1/session/c3
[    40.103] (II) xfree86: Adding drm device (/dev/dri/card0)
[    40.104] (II) systemd-logind: got fd for /dev/dri/card0 226:0 fd 12 paused 0
[    40.106] (--) PCI:*(0:1:0:0) 10de:1287:3842:3733 rev 161, Mem @ 0xde000000/16777216, 0xd0000000/134217728, 0xd8000000/33554432, I/O @ 0x0000dc80/128, BIOS @ 0x????????/131072
[    40.106] (WW) "glamoregl" will not be loaded unless you've specified it to be loaded elsewhere.
[    40.106] (II) "glx" will be loaded by default.
[    40.106] (II) LoadModule: "glx"
[    40.147] (II) Loading /usr/lib/x86_64-linux-gnu/xorg/extra-modules/libglx.so
[    41.521] (II) Module glx: vendor="NVIDIA Corporation"
[    41.521]     compiled for 4.0.2, module version = 1.0.0
[    41.521]     Module class: X.Org Server Extension
[    41.526] (II) NVIDIA GLX Module  384.111  Tue Dec 19 22:51:13 PST 2017
[    41.541] (==) Matched nvidia as autoconfigured driver 0
[    41.541] (==) Matched nouveau as autoconfigured driver 1
[    41.541] (==) Matched nvidia as autoconfigured driver 2
[    41.541] (==) Matched nouveau as autoconfigured driver 3
[    41.541] (==) Matched modesetting as autoconfigured driver 4
[    41.541] (==) Matched fbdev as autoconfigured driver 5
[    41.541] (==) Matched vesa as autoconfigured driver 6
[    41.541] (==) Assigned the driver to the xf86ConfigLayout
[    41.541] (II) LoadModule: "nvidia"
[    41.541] (II) Loading /usr/lib/x86_64-linux-gnu/xorg/extra-modules/nvidia_drv.so
[    41.728] (II) Module nvidia: vendor="NVIDIA Corporation"
[    41.728]     compiled for 4.0.2, module version = 1.0.0
[    41.728]     Module class: X.Org Video Driver
[    41.737] (II) LoadModule: "nouveau"
[    41.762] (II) Loading /usr/lib/xorg/modules/drivers/nouveau_drv.so
[    41.827] (II) Module nouveau: vendor="X.Org Foundation"
[    41.827]     compiled for 1.19.3, module version = 1.0.15
[    41.827]     Module class: X.Org Video Driver
[    41.828]     ABI class: X.Org Video Driver, version 23.0
[    41.828] (II) LoadModule: "modesetting"
[    41.828] (II) Loading /usr/lib/xorg/modules/drivers/modesetting_drv.so
[    41.834] (II) Module modesetting: vendor="X.Org Foundation"
[    41.834]     compiled for 1.19.5, module version = 1.19.5
[    41.834]     Module class: X.Org Video Driver
[    41.834]     ABI class: X.Org Video Driver, version 23.0
[    41.834] (II) LoadModule: "fbdev"
[    41.834] (II) Loading /usr/lib/xorg/modules/drivers/fbdev_drv.so
[    41.834] (II) Module fbdev: vendor="X.Org Foundation"
[    41.835]     compiled for 1.19.3, module version = 0.4.4
[    41.835]     Module class: X.Org Video Driver
[    41.835]     ABI class: X.Org Video Driver, version 23.0
[    41.835] (II) LoadModule: "vesa"
[    41.835] (II) Loading /usr/lib/xorg/modules/drivers/vesa_drv.so
[    41.840] (II) Module vesa: vendor="X.Org Foundation"
[    41.840]     compiled for 1.19.3, module version = 2.3.4
[    41.840]     Module class: X.Org Video Driver
[    41.840]     ABI class: X.Org Video Driver, version 23.0
[    41.840] (II) NVIDIA dlloader X Driver  384.111  Tue Dec 19 22:25:34 PST 2017
[    41.840] (II) NVIDIA Unified Driver for all Supported NVIDIA GPUs
[    41.855] (II) NOUVEAU driver Date:   Fri Apr 21 14:41:17 2017 -0400
[    41.855] (II) NOUVEAU driver for NVIDIA chipset families :
[    41.855]     RIVA TNT        (NV04)
[    41.855]     RIVA TNT2       (NV05)
[    41.855]     GeForce 256     (NV10)
[    41.855]     GeForce 2       (NV11, NV15)
[    41.856]     GeForce 4MX     (NV17, NV18)
[    41.856]     GeForce 3       (NV20)
[    41.856]     GeForce 4Ti     (NV25, NV28)
[    41.856]     GeForce FX      (NV3x)
[    41.856]     GeForce 6       (NV4x)
[    41.856]     GeForce 7       (G7x)
[    41.856]     GeForce 8       (G8x)
[    41.856]     GeForce GTX 200 (NVA0)
[    41.856]     GeForce GTX 400 (NVC0)
[    41.856] (II) modesetting: Driver for Modesetting Kernel Drivers: kms
[    41.856] (II) FBDEV: driver for framebuffer: fbdev
[    41.856] (II) VESA: driver for VESA chipsets: vesa
[    41.856] (II) systemd-logind: releasing fd for 226:0
[    41.866] (II) Loading sub module "fb"
[    41.866] (II) LoadModule: "fb"
[    41.867] (II) Loading /usr/lib/xorg/modules/libfb.so
[    41.885] (II) Module fb: vendor="X.Org Foundation"
[    41.885]     compiled for 1.19.5, module version = 1.0.0
[    41.885]     ABI class: X.Org ANSI C Emulation, version 0.4
[    41.885] (II) Loading sub module "wfb"
[    41.885] (II) LoadModule: "wfb"
[    41.886] (II) Loading /usr/lib/xorg/modules/libwfb.so
[    41.896] (II) Module wfb: vendor="X.Org Foundation"
[    41.896]     compiled for 1.19.5, module version = 1.0.0
[    41.896]     ABI class: X.Org ANSI C Emulation, version 0.4
[    41.896] (II) Loading sub module "ramdac"
[    41.896] (II) LoadModule: "ramdac"
[    41.896] (II) Module "ramdac" already built-in
[    42.069] (WW) Falling back to old probe method for modesetting
[    42.069] (WW) Falling back to old probe method for fbdev
[    42.069] (II) Loading sub module "fbdevhw"
[    42.069] (II) LoadModule: "fbdevhw"
[    42.069] (II) Loading /usr/lib/xorg/modules/libfbdevhw.so
[    42.091] (II) Module fbdevhw: vendor="X.Org Foundation"
[    42.091]     compiled for 1.19.5, module version = 0.0.2
[    42.091]     ABI class: X.Org Video Driver, version 23.0
[    42.091] (WW) Falling back to old probe method for vesa
[    42.091] (II) NVIDIA(0): Creating default Display subsection in Screen section
    "Default Screen Section" for depth/fbbpp 24/32
[    42.091] (==) NVIDIA(0): Depth 24, (==) framebuffer bpp 32
[    42.091] (==) NVIDIA(0): RGB weight 888
[    42.091] (==) NVIDIA(0): Default visual is TrueColor
[    42.091] (==) NVIDIA(0): Using gamma correction (1.0, 1.0, 1.0)
[    42.107] (**) NVIDIA(0): Enabling 2D acceleration
[    42.672] (--) NVIDIA(0): Valid display device(s) on GPU-0 at PCI:1:0:0
[    42.672] (--) NVIDIA(0):     CRT-0
[    42.673] (--) NVIDIA(0):     DFP-0 (boot)
[    42.673] (--) NVIDIA(0):     DFP-1
[    42.676] (II) NVIDIA(0): NVIDIA GPU GeForce GT 730 (GK208) at PCI:1:0:0 (GPU-0)
[    42.676] (--) NVIDIA(0): Memory: 2097152 kBytes
[    42.676] (--) NVIDIA(0): VideoBIOS: 80.28.78.00.34
[    42.677] (II) NVIDIA(0): Detected PCI Express Link width: 8X
[    42.707] (--) NVIDIA(GPU-0): EMA e15t4 (CRT-0): connected
[    42.707] (--) NVIDIA(GPU-0): EMA e15t4 (CRT-0): 400.0 MHz maximum pixel clock
[    42.722] (--) NVIDIA(GPU-0): DELL 1800FP (DFP-0): connected
[    42.722] (--) NVIDIA(GPU-0): DELL 1800FP (DFP-0): Internal TMDS
[    42.722] (--) NVIDIA(GPU-0): DELL 1800FP (DFP-0): 330.0 MHz maximum pixel clock
[    42.723] (--) NVIDIA(GPU-0): DFP-1: disconnected
[    42.723] (--) NVIDIA(GPU-0): DFP-1: Internal TMDS
[    42.723] (--) NVIDIA(GPU-0): DFP-1: 165.0 MHz maximum pixel clock
[    42.798] (==) NVIDIA(0):
[    42.798] (==) NVIDIA(0): No modes were requested; the default mode "nvidia-auto-select"
[    42.798] (==) NVIDIA(0):     will be used as the requested mode.
[    42.838] (II) NVIDIA(0): Validated MetaModes:
[    42.838] (II) NVIDIA(0):     "DFP-0:nvidia-auto-select,CRT-0:nvidia-auto-select"
[    42.838] (II) NVIDIA(0): Virtual screen size determined to be 2304 x 1024
[    42.843] (--) NVIDIA(0): DPI set to (90, 89); computed from "UseEdidDpi" X config
[    42.843] (--) NVIDIA(0):     option
[    42.843] (II) UnloadModule: "nouveau"
[    42.843] (II) Unloading nouveau
[    42.843] (II) UnloadModule: "modesetting"
[    42.843] (II) Unloading modesetting
[    42.843] (II) UnloadModule: "fbdev"
[    42.843] (II) Unloading fbdev
[    42.843] (II) UnloadSubModule: "fbdevhw"
[    42.843] (II) Unloading fbdevhw
[    42.843] (II) UnloadModule: "vesa"
[    42.843] (II) Unloading vesa
[    42.844] (--) Depth 24 pixmap format is 32 bpp
[    42.844] (II) NVIDIA: Using 6144.00 MB of virtual memory for indirect memory
[    42.844] (II) NVIDIA:     access.
[    42.910] (II) NVIDIA(0): Setting mode "DFP-0:nvidia-auto-select,CRT-0:nvidia-auto-select"
[    43.000] (==) NVIDIA(0): Disabling shared memory pixmaps
[    43.000] (==) NVIDIA(0): Backing store enabled
[    43.000] (==) NVIDIA(0): Silken mouse enabled
[    43.002] (==) NVIDIA(0): DPMS enabled
[    43.024] (II) Loading sub module "dri2"
[    43.024] (II) LoadModule: "dri2"
[    43.024] (II) Module "dri2" already built-in
[    43.024] (II) NVIDIA(0): [DRI2] Setup complete
[    43.024] (II) NVIDIA(0): [DRI2]   VDPAU driver: nvidia
[    43.025] (--) RandR disabled
[    43.048] (II) SELinux: Disabled on system
[    43.049] (II) Initializing extension GLX
[    43.049] (II) Indirect GLX disabled.
[    43.480] (II) config/udev: Adding input device Power Button (/dev/input/event1)
[    43.480] (**) Power Button: Applying InputClass "libinput keyboard catchall"
[    43.481] (II) LoadModule: "libinput"
[    43.490] (II) Loading /usr/lib/xorg/modules/input/libinput_drv.so
[    43.501] (II) Module libinput: vendor="X.Org Foundation"
[    43.501]     compiled for 1.19.3, module version = 0.25.0
[    43.502]     Module class: X.Org XInput Driver
[    43.502]     ABI class: X.Org XInput driver, version 24.1
[    43.502] (II) Using input driver 'libinput' for 'Power Button'
[    43.506] (II) systemd-logind: got fd for /dev/input/event1 13:65 fd 38 paused 0
[    43.506] (**) Power Button: always reports core events
[    43.506] (**) Option "Device" "/dev/input/event1"
[    43.507] (**) Option "_source" "server/udev"
[    43.508] (II) event1  - (II) Power Button: (II) is tagged by udev as: Keyboard
[    43.508] (II) event1  - (II) Power Button: (II) device is a keyboard
[    43.508] (II) event1  - (II) Power Button: (II) device removed
[    43.509] (**) Option "config_info" "udev:/sys/devices/LNXSYSTM:00/LNXPWRBN:00/input/input1/event1"
[    43.510] (II) XINPUT: Adding extended input device "Power Button" (type: KEYBOARD, id 6)
[    43.510] (**) Option "xkb_model" "pc105"
[    43.510] (**) Option "xkb_layout" "us"
[    43.510] (**) Option "xkb_options" "compose:ralt,terminate:ctrl_alt_bksp"
[    43.548] (II) event1  - (II) Power Button: (II) is tagged by udev as: Keyboard
[    43.548] (II) event1  - (II) Power Button: (II) device is a keyboard
[    43.549] (II) config/udev: Adding input device Power Button (/dev/input/event0)
[    43.550] (**) Power Button: Applying InputClass "libinput keyboard catchall"
[    43.550] (II) Using input driver 'libinput' for 'Power Button'
[    43.553] (II) systemd-logind: got fd for /dev/input/event0 13:64 fd 41 paused 0
[    43.554] (**) Power Button: always reports core events
[    43.554] (**) Option "Device" "/dev/input/event0"
[    43.554] (**) Option "_source" "server/udev"
[    43.555] (II) event0  - (II) Power Button: (II) is tagged by udev as: Keyboard
[    43.556] (II) event0  - (II) Power Button: (II) device is a keyboard
[    43.556] (II) event0  - (II) Power Button: (II) device removed
[    43.556] (**) Option "config_info" "udev:/sys/devices/LNXSYSTM:00/LNXSYBUS:00/PNP0C0C:00/input/input0/event0"
[    43.557] (II) XINPUT: Adding extended input device "Power Button" (type: KEYBOARD, id 7)
[    43.557] (**) Option "xkb_model" "pc105"
[    43.558] (**) Option "xkb_layout" "us"
[    43.558] (**) Option "xkb_options" "compose:ralt,terminate:ctrl_alt_bksp"
[    43.559] (II) event0  - (II) Power Button: (II) is tagged by udev as: Keyboard
[    43.559] (II) event0  - (II) Power Button: (II) device is a keyboard
[    43.561] (II) config/udev: Adding input device HDA NVidia HDMI/DP,pcm=3 (/dev/input/event9)
[    43.561] (II) No input driver specified, ignoring this device.
[    43.561] (II) This device may have been added with another device file.
[    43.562] (II) config/udev: Adding input device HDA NVidia HDMI/DP,pcm=7 (/dev/input/event10)
[    43.563] (II) No input driver specified, ignoring this device.
[    43.563] (II) This device may have been added with another device file.
[    43.564] (II) config/udev: Adding input device HDA Intel Line Out (/dev/input/event7)
[    43.564] (II) No input driver specified, ignoring this device.
[    43.564] (II) This device may have been added with another device file.
[    43.565] (II) config/udev: Adding input device HDA Intel Front Headphone (/dev/input/event8)
[    43.565] (II) No input driver specified, ignoring this device.
[    43.566] (II) This device may have been added with another device file.
[    43.566] (II) config/udev: Adding input device HDA Intel Mic (/dev/input/event5)
[    43.567] (II) No input driver specified, ignoring this device.
[    43.567] (II) This device may have been added with another device file.
[    43.568] (II) config/udev: Adding input device HDA Intel Line (/dev/input/event6)
[    43.568] (II) No input driver specified, ignoring this device.
[    43.569] (II) This device may have been added with another device file.
[    43.570] (II) config/udev: Adding input device C-Media Electronics Inc.       USB PnP Sound Device (/dev/input/event2)
[    43.570] (**) C-Media Electronics Inc.       USB PnP Sound Device: Applying InputClass "libinput keyboard catchall"
[    43.570] (II) Using input driver 'libinput' for 'C-Media Electronics Inc.       USB PnP Sound Device'
[    43.574] (II) systemd-logind: got fd for /dev/input/event2 13:66 fd 42 paused 0
[    43.574] (**) C-Media Electronics Inc.       USB PnP Sound Device: always reports core events
[    43.574] (**) Option "Device" "/dev/input/event2"
[    43.575] (**) Option "_source" "server/udev"
[    43.576] (II) event2  - (II) C-Media Electronics Inc.       USB PnP Sound Device: (II) is tagged by udev as: Keyboard
[    43.576] (II) event2  - (II) C-Media Electronics Inc.       USB PnP Sound Device: (II) device is a keyboard
[    43.576] (II) event2  - (II) C-Media Electronics Inc.       USB PnP Sound Device: (II) device removed
[    43.577] (**) Option "config_info" "udev:/sys/devices/pci0000:00/0000:00:1d.1/usb3/3-1/3-1:1.3/0003:0D8C:013C.0001/input/input5/event2"
[    43.578] (II) XINPUT: Adding extended input device "C-Media Electronics Inc.       USB PnP Sound Device" (type: KEYBOARD, id 8)
[    43.578] (**) Option "xkb_model" "pc105"
[    43.578] (**) Option "xkb_layout" "us"
[    43.578] (**) Option "xkb_options" "compose:ralt,terminate:ctrl_alt_bksp"
[    43.580] (II) event2  - (II) C-Media Electronics Inc.       USB PnP Sound Device: (II) is tagged by udev as: Keyboard
[    43.580] (II) event2  - (II) C-Media Electronics Inc.       USB PnP Sound Device: (II) device is a keyboard
[    43.582] (II) config/udev: Adding input device USB Optical Mouse (/dev/input/event3)
[    43.582] (**) USB Optical Mouse: Applying InputClass "libinput pointer catchall"
[    43.582] (II) Using input driver 'libinput' for 'USB Optical Mouse'
[    43.586] (II) systemd-logind: got fd for /dev/input/event3 13:67 fd 43 paused 0
[    43.586] (**) USB Optical Mouse: always reports core events
[    43.586] (**) Option "Device" "/dev/input/event3"
[    43.586] (**) Option "_source" "server/udev"
[    43.587] (II) event3  - (II) USB Optical Mouse: (II) is tagged by udev as: Mouse
[    43.587] (II) event3  - (II) USB Optical Mouse: (II) device is a pointer
[    43.587] (II) event3  - (II) USB Optical Mouse: (II) device removed
[    43.587] (**) Option "config_info" "udev:/sys/devices/pci0000:00/0000:00:1d.2/usb4/4-1/4-1:1.0/0003:0461:4D22.0002/input/input6/event3"
[    43.587] (II) XINPUT: Adding extended input device "USB Optical Mouse" (type: MOUSE, id 9)
[    43.589] (**) Option "AccelerationScheme" "none"
[    43.589] (**) USB Optical Mouse: (accel) selected scheme none/0
[    43.589] (**) USB Optical Mouse: (accel) acceleration factor: 2.000
[    43.589] (**) USB Optical Mouse: (accel) acceleration threshold: 4
[    43.590] (II) event3  - (II) USB Optical Mouse: (II) is tagged by udev as: Mouse
[    43.590] (II) event3  - (II) USB Optical Mouse: (II) device is a pointer
[    43.591] (II) config/udev: Adding input device USB Optical Mouse (/dev/input/mouse0)
[    43.591] (II) No input driver specified, ignoring this device.
[    43.591] (II) This device may have been added with another device file.
[    43.594] (II) config/udev: Adding input device Dell Dell USB Keyboard (/dev/input/event4)
[    43.595] (**) Dell Dell USB Keyboard: Applying InputClass "libinput keyboard catchall"
[    43.595] (II) Using input driver 'libinput' for 'Dell Dell USB Keyboard'
[    43.598] (II) systemd-logind: got fd for /dev/input/event4 13:68 fd 44 paused 0
[    43.598] (**) Dell Dell USB Keyboard: always reports core events
[    43.598] (**) Option "Device" "/dev/input/event4"
[    43.598] (**) Option "_source" "server/udev"
[    43.599] (II) event4  - (II) Dell Dell USB Keyboard: (II) is tagged by udev as: Keyboard
[    43.599] (II) event4  - (II) Dell Dell USB Keyboard: (II) device is a keyboard
[    43.599] (II) event4  - (II) Dell Dell USB Keyboard: (II) device removed
[    43.599] (**) Option "config_info" "udev:/sys/devices/pci0000:00/0000:00:1d.2/usb4/4-2/4-2:1.0/0003:413C:2105.0003/input/input7/event4"
[    43.599] (II) XINPUT: Adding extended input device "Dell Dell USB Keyboard" (type: KEYBOARD, id 10)
[    43.599] (**) Option "xkb_model" "pc105"
[    43.599] (**) Option "xkb_layout" "us"
[    43.599] (**) Option "xkb_options" "compose:ralt,terminate:ctrl_alt_bksp"
[    43.600] (II) event4  - (II) Dell Dell USB Keyboard: (II) is tagged by udev as: Keyboard
[    43.600] (II) event4  - (II) Dell Dell USB Keyboard: (II) device is a keyboard
[    45.362] (--) NVIDIA(GPU-0): EMA e15t4 (CRT-0): connected
[    45.363] (--) NVIDIA(GPU-0): EMA e15t4 (CRT-0): 400.0 MHz maximum pixel clock
[    45.380] (--) NVIDIA(GPU-0): DELL 1800FP (DFP-0): connected
[    45.380] (--) NVIDIA(GPU-0): DELL 1800FP (DFP-0): Internal TMDS
[    45.380] (--) NVIDIA(GPU-0): DELL 1800FP (DFP-0): 330.0 MHz maximum pixel clock
[    45.381] (--) NVIDIA(GPU-0):
[    45.381] (--) NVIDIA(GPU-0): DFP-1: disconnected
[    45.382] (--) NVIDIA(GPU-0): DFP-1: Internal TMDS
[    45.382] (--) NVIDIA(GPU-0): DFP-1: 165.0 MHz maximum pixel clock
[    45.901] (II) NVIDIA(0): Setting mode "VGA-0: nvidia-auto-select @1024x768 +0+0 {ViewPortIn=1024x768, ViewPortOut=1024x768+0+0}"
[    45.962] (II) NVIDIA(0): Setting mode "VGA-0: nvidia-auto-select @1024x768 +0+0 {ViewPortIn=1024x768, ViewPortOut=1024x768+0+0}, DVI-D-0: nvidia-auto-select @1280x1024 +1024+0 {ViewPortIn=1280x1024, ViewPortOut=1280x1024+0+0}"
[    58.333] (--) NVIDIA(GPU-0): EMA e15t4 (CRT-0): connected
[    58.334] (--) NVIDIA(GPU-0): EMA e15t4 (CRT-0): 400.0 MHz maximum pixel clock
[    58.349] (--) NVIDIA(GPU-0): DELL 1800FP (DFP-0): connected
[    58.349] (--) NVIDIA(GPU-0): DELL 1800FP (DFP-0): Internal TMDS
[    58.349] (--) NVIDIA(GPU-0): DELL 1800FP (DFP-0): 330.0 MHz maximum pixel clock
[    58.349] (--) NVIDIA(GPU-0): DFP-1: disconnected
[    58.349] (--) NVIDIA(GPU-0): DFP-1: Internal TMDS
[    58.349] (--) NVIDIA(GPU-0): DFP-1: 165.0 MHz maximum pixel clock
[    82.695] (**) Option "fd" "38"
[    82.695] (II) event1  - (II) Power Button: (II) device removed
[    82.696] (**) Option "fd" "41"
[    82.696] (II) event0  - (II) Power Button: (II) device removed
[    82.696] (**) Option "fd" "42"
[    82.696] (II) event2  - (II) C-Media Electronics Inc.       USB PnP Sound Device: (II) device removed
[    82.697] (**) Option "fd" "43"
[    82.697] (II) event3  - (II) USB Optical Mouse: (II) device removed
[    82.697] (**) Option "fd" "44"
[    82.697] (II) event4  - (II) Dell Dell USB Keyboard: (II) device removed
[    82.805] (II) systemd-logind: got pause for 13:65
[    82.806] (II) systemd-logind: got pause for 13:64
[    82.806] (II) systemd-logind: got pause for 13:67
[    82.806] (II) systemd-logind: got pause for 13:66
[    82.807] (II) systemd-logind: got pause for 13:68
I'm also working on uploading some files to show. This time after the freeze the audio started to show signs of X-runs occuring (Some sort of buffer error causing repeating audio) and eventually the audio stopped. The num lock was froxen since the keyboard is owned by Xorg but the kernel was still somewhat intact since SysRQ still reponded. Brb with the files.
EDIT: Here are the files.
Audio: https://drive.google.com/file/d/1nXs7XUMjJgpQRr936vHeMMUBJsMrydzj/view?usp=sharing
Video: https://drive.google.com/file/d/1ShXNZAeIEUwPPqhG-HFpBVsfgFovd8jV/view?usp=sharing
https://linustechtips.com/topic/882698-random-system-freezes/#findComment-10923958
Getting the exact same freezes with audio working here on a new Ryzen Build. Mine is freezing when I try to open more then 3 files in office calc or if I try to format a cell.
Have you tried switching between Xorg and Wayland ? Since I switched back to Xorg, I only freeze with calc where before it would freeze randomly and frequently.
https://itsfoss.com/switch-xorg-wayland/
https://linustechtips.com/topic/882698-random-system-freezes/#findComment-10925282
I'll try that and get back soon. Totally forgot Wayland is default now!;)
https://linustechtips.com/topic/882698-random-system-freezes/#findComment-10927794
