I don't know how to approach this problem.
Happening for quite a while now ( :( )
The problem is that is now I use a laptop for apparently all tasks now. (I will upgrade the PC later, exams for now) So, I thought to use the monitor previously for the PC
So I did just that and it works fine but some games refuse to run Full Screen. (NFS MW 12,for ex.) and as for the other games, (like CSGO) it refuses to run at specific resolutions (take 1280x960, for ex.)  with an error "Input Not Supported" for all issues
  • For games like NFS, I may have to reduce resolution (not sure, just assuming)
  • My laptop doesn't have a VGA port, I use HDMI to VGA adapter (old monitor)
  • both laptop and monitor have native resolution 1366x768 @ 60Hz (monitor port is only VGA)
  • display adapters include HD 620 and 940MX
Thank you in advance, looking forward to your help. :)
Ryzen 5 9600x | Asrock 9060XT 16GB OC | Gigabyte B850M Gaming X WIFI32GB DDR5-5200 | SDEJava & Golang
anyone got a spare job here?
https://linustechtips.com/topic/882472-random-input-not-supported-error/
If your monitor is a 1366x768, both those numbers are maximums, so you could not go higher (ex: 1280x960 is too high on the vertical resolution).
You need to keep both numbers at or below 1366 & 768
Look up your monitor online, find the manual.  It will have a list of supported resolutions.  You can only use the ones that are supported.  You might not be able to do other resolutions below the panel size either (for example 1280x720 might not work)
Main Rig:
Case: Lian Li Lancool Mesh RGB
CPU: Ryzen 5 3600
Cooler: CoolerMaster MasterLiquid 240
MB: MSI B550 Gaming Pro Carbon
Ram: Gskill DDR4 3600 x 32GB
GPU: Asus Arez Strix Vega 64 OC
PS: Seasonic FOCUS Gold Plus Series SSR-750FX
SSD1: Crucial P1 1TB NVME
SSD2: Adata SU800 512gb M.2 Sata
HDD: Hitatchi 2tb 7200RPM + 3x 2TB WD Passport USB 3.0
Monitors: AOC C24G1
Keyboard: Cheap Blue Knockoff Mechanical
Mouse: Uhuru Gaming Mouse
OS: Pop! 21.04
Current Vintage Equipment:  Please ask me about it, I love to talk old tech!
IBM Thinkpad 390, IBM Aptiva A12, IBM PS/2 Model 25-004.  Compaq Contura 4/25C, Presario 7596
Asus P5A-B Socket 7 Box, Tandy 1000RLX-HD "B" & 1200-2FD, VIC20, Zenith ZFL-181-93, Packard Bell 300SX.
Apple II/gs, Mac Plus x2, Mac SE x2, Performa 450
I thought just that.
Wierd part is that CS:GO runs fine when on PC (direct vga to vga connection) on 1280*960 (GT 730 GPU)
Even windows lists 1280*960 @ 60Hz as a display mode (on my PC only)  :-\
But still, I will try and let you know.
