Hi guys ,
I am gaming on a ryzen 1700x with a 1080ti , when i am on less damaging games like  L4d2 and cs go i am getting frame rates of  >60 which is pretty ridiculous  .  =(
- Turned off v-sync
- switching to high performance mode.
- installed the latest driver / reinstalled
How can i bump up the frame rates ?
Spec  :
ryzen 1700x
asus crosshair extreme
32gb cosair dominator platinum  3000mhz  running at 2100mghz
asus strix 1080ti
acer x34a
https://linustechtips.com/topic/882383-low-fps/
What kind of connection do you have to the monitor?
You could be limited by your monitor cable. Like I can't power my 3440x1440 one from HDMI over 30fps. And I once bought a 'cheap' Displayport cable and it even limited my FPS.
Something to consider, as everything else in your system seems to check in.
https://linustechtips.com/topic/882383-low-fps/#findComment-10904202
mine is the display connector that came with my x34a , the thing is on demanding games like just cause 3 and rainbow 6 sedge  on very high settings, i am getting 85- 100 fps which is acceptable but shouldn't l4d2 and csgo be around the 300frames region . my 770 can hit 250 with no sweat .
https://linustechtips.com/topic/882383-low-fps/#findComment-10904209
Technically should, and at this point I'm kinda at a loss. Other than reinstalling the game, drivers, disabling Game Mode in Windows 10, and making sure all adaptive and V-sync is off, you should be flying.
However, something to consider anyway, don't run games faster than your monitors refresh rate. You can overclock your monitor (usually a safe overclock for a 60hz IPS monitor is 75hz, nVidia control panel makes this easy) which will make things noticeably smoother, but if you go excessive, like 300 fps on a monitor that can only do 60, thats 240 frames that you will not see anyway.
https://linustechtips.com/topic/882383-low-fps/#findComment-10904216
after doing all of that still nothing so far . even in the main screen in l4d2 i am bouncing around 72 to 80 fraps in a single player game my frames drop to 60 .
https://linustechtips.com/topic/882383-low-fps/#findComment-10904318
